Looking for ring and pinion gears
Old Mar 7, 2014 | 06:19 AM
Tim305's Avatar
1969 cutlass convertible
I'm Looking for a 3:42 or3:23 ring and pinion gear for a 69 cutlass type o differential.
Old Mar 7, 2014 | 07:17 AM
oldsmobiledave's Avatar
more info needed
Not enough info.
OEM 3.23 & 3.42 gears use two distinct carriers.
Aftermarket Richmond 3.42s will work on the OEM 3.23 carrier.
Which are you after?
Old Mar 7, 2014 | 11:57 AM
Tim305's Avatar
I will take what I can find and probably change the carrier if need be. I'm not sure right now what I have just know it open and stock on a 350 2 bbl car . A new carrier seems easier to find then the gears either that or I'll have to change out the whole thing to a corp clip togetwhat I want.
Old Mar 8, 2014 | 04:26 PM
Gary M's Avatar
May have something
I bought a 323 set from West Coast Differentials for my 10 bolt. The gear set I got is #GM-8.5-323 and install kit # IK GM8.5E. On the WCD website you can check if these will work for you. They are new in box, I paid $401.10 for them and then found out I have that gear in car already. If they will work on your car I will sell them for $300.00 shipped to you in Michigan.
Old Mar 8, 2014 | 05:05 PM
FYi
That crown & pinion is for a 10 bolt & will not work in a Type O 12 bolt.
Old Mar 8, 2014 | 05:12 PM
Gary M's Avatar
Did not know O type was 12 bolt. Sorry. West Coast differentials may have what he needs but not cheap and if possible go with the OEM gears because they (WCD) told me those are less likely to be noisy like some aftermarket gear sets. Good luck.
Old Mar 8, 2014 | 05:56 PM
jensenracing77's Avatar
joesw31 has a set of 3.42 gears for the O type.
Old Mar 8, 2014 | 06:15 PM
more info needed
Do you know if they are OEM or Richmond? (ie for which carrier?).
Old Mar 8, 2014 | 06:46 PM
If he still has them they are OEM. They were listed here in the parts for sale section a month or two ago. Look back through them and it should be there. I am sure he will see this thread soon.
Old Mar 9, 2014 | 06:33 AM
Tim305's Avatar
Thanx ill pm him
dewcrazzy
Jul 12, 2013 03:21 PM
monzaz
Feb 26, 2012 08:23 PM
monzaz
Nov 24, 2011 08:35 PM
monzaz
Nov 8, 2011 05:35 PM
halfmoontrail
Aug 12, 2011 07:10 AM
