looking for Parking brake wire for my 53 Olds 98
Old Feb 3, 2013 | 01:56 AM
stocki26's Avatar
Hi,
actually I am restoring my 1953 Olds 98 Sedan.
Parking brake left side didnt work, rear wheel cylinder was wet.
Wheel cylinder repair kit I will order at Fusick, no problem, but ....where can I find a left side parking brake wire ?
If available I would also buy both sides, right side is ok but also has rust, left side is very bad and it would be last thing I want to do not to change that part.
After very much time of trying to repair it the wire can be moved in the tube, but is very much full of rust and will not work for long
Old Feb 3, 2013 | 11:26 AM
m371961's Avatar
If the internal cable is not frayed with broken strands, you may try warming it with a heat gun and soaking it for a few days in the bottom of a bucket covered in ATF.
Unless a replacement is easy and cheap to find.
Old Feb 3, 2013 | 11:52 AM
stocki26's Avatar
Outside cable is very rusty and broken at some spots ...
and, I should have written, me and my Olds are in Austria ......
here no chance to find such a part.
So maybe you can tell me where to order ?
Old Feb 5, 2013 | 02:22 PM
stocki26's Avatar
all is fine, Steve from Fusick has answered and told me that he is able to deliver the parking brake cable
Old Feb 6, 2013 | 11:36 AM
mpolds's Avatar
Rear Brake Wheel Cylinder & Brake Cables
If you haven't ordered them already -- I have the rear wheel cylinders in stock @ $ 15.00 each (USA dollars) and the rear brake cables in stock (left & right rear) @ $ 55.00 each (USA dollars) plus USPS actual shipping.
Just read your request -- don't know if you've already ordered.....
Old Feb 6, 2013 | 12:26 PM
stocki26's Avatar
Order has already been sent yesterday, sorry. Actually I am waiting for answer.
If there is any trouble I will send an PM to you ... ;o)
Old Feb 6, 2013 | 12:38 PM
mpolds's Avatar
Responding to your response!!
If you get problems from them, or can go ahead and cancel, because their prices are too high (which is a certainty, I'm sure.),
Let me know, indeed....
I don't have my own computer, have to go to the library to use it, and am not here every day. Today is Weds., Feb. 5th. I will definitely not be able to get here tomorrow (Thursday)....
I will come here on Friday -- specifically to check to see if you need me...
Thank you, Craig -- 516 - 485 - 1935... New York....
Old Feb 13, 2013 | 08:57 AM
stocki26's Avatar
all parts have arrived today, so I know what to do next weekend ;o)
Kilmster
Brakes/Hydraulic Systems
Aug 6, 2014 05:41 PM
jimigisme
Jan 29, 2014 08:26 PM
jimigisme
Jan 29, 2014 06:45 PM
jtchrist
Apr 4, 2012 04:54 PM
racevet
Sep 21, 2011 02:55 PM
