Looking for a connecting rod
Old Jan 22, 2025 | 07:40 AM
Tirediron's Avatar
I need one standard conn rod for a 455. I spun a rod bearing on #8. If an OEM piston is on it, that's fine, too.
Thanks!
Old Jan 22, 2025 | 08:08 AM
ROCKETMAN269V's Avatar
I have rods as well as rod/piston combinations. High compression or low compression piston? Thanks, Bob.
Old Jan 22, 2025 | 09:15 AM
Tirediron's Avatar
Hi Bob,
since im a newbie, I dobt know if they're high or low! Can you tell from this picture?
Old Jan 22, 2025 | 09:43 AM
rickw30's Avatar
I have Rods if needed.
631-433-7278.
Rick
Old Jan 22, 2025 | 12:15 PM
66_Jetstar's Avatar
Unless it's hurt real bad any machine shop should be able to resize it. You should also have it's partner resized. At the very least check it. I'd bet a cold beer it needs fixed as well.
Old Jan 22, 2025 | 09:01 PM
Tirediron's Avatar
That's good advice. Someone else was telling me about the resizing process, so I'll check that out. Is it generally cheaper to resize than buy a new rod (as well as get it pressed and put back in etc.)?
thanks.
Old Jan 22, 2025 | 11:45 PM
66_Jetstar's Avatar
The piston can stay on the rod for the process.
Al2011
Sep 25, 2013 05:07 PM
805cut
Jun 11, 2012 05:06 AM
craftsman1956
Suspension & Handling
Jul 16, 2010 09:56 PM
mb197942
Sep 5, 2008 08:47 AM
