Looking for 1972 t3 low beam bullbs
Old Jul 31, 2021 | 06:35 PM
72455's Avatar
1972 U code Supreme
Need one (preferably 2) 1972 t3 low beam bulbs. These have the "t3" markings at the bottom, not the triangle in the center.
Old Aug 1, 2021 | 08:40 AM
pappy's Avatar
There is a pair of low beams on evil bay now. No affiliation on my part.
Old Aug 1, 2021 | 09:30 AM
72455's Avatar
1972 U code Supreme
Yup..saw those for 97 bones but not been tested..not gonna lay down that kinda green on something that may or may not work.
Old Aug 1, 2021 | 11:43 AM
PatL's Avatar
love that cop out that is becoming more common on Ebay: "Not been tested" especially on easy to test stuff, Gets them off the hook, but I pass every single time...…….
Old Aug 1, 2021 | 12:14 PM
rocketraider's Avatar
Oldsdruid
Unless you're going for a 1000-point restoration or never plan to drive the car after dark, why would you even want them?
At least 73-later Guide PowerBeams gave you better light.
Old Aug 1, 2021 | 03:53 PM
72455's Avatar
1972 U code Supreme
Because I've tried aftermarket and they don't fit right...
Old Aug 1, 2021 | 04:09 PM
Really? I’ve used aftermarket in both my 70 Supreme and 71 convertible since the 80s with no fitment issues.
Old Aug 1, 2021 | 05:28 PM
72455's Avatar
1972 U code Supreme
Yesssir...even an OEM from 70-71 doesn't fit quite as snug as a 72....dunno why but maybe that's why the 72s are few and far between.
Old Aug 1, 2021 | 06:39 PM
Oldsdruid
I had a 72 Supreme from 1988-94 and Wagner, GE, and Sylvania all fit without issues. Has your car ever taken a front end hit?
Old Aug 1, 2021 | 07:29 PM
The headlight buckets and retainers on a 72 are no different than the other years, so if there is something preventing the headlights from fitting properly on your car, the issue is most likely with your car and not the aftermarket headlights. Can’t really say too much without seeing what the issue is, though.
Old Aug 1, 2021 | 07:44 PM
tru-blue 442's Avatar
Old School Olds
72, I'll dig through my stash and see if I have one. Remind me, 2 or 3 prong? I forget.
Old Aug 1, 2021 | 08:28 PM
Oldsdruid
2 prong hi beam (inner lamp), 3 prong low/combination beam (outer lamp).
Old Aug 2, 2021 | 06:21 AM
Old School Olds
Figures. The only T-3 that I have like he wants is a high beam 2 prong.
Old Aug 2, 2021 | 07:45 AM
72455's Avatar
1972 U code Supreme
So after some digging into my memory banks, I remembered why I went with the '72 only bulb. I was originally going to switch to halogens, but the screws for the driver side ring were seized, so I stayed with original low beams. When the passenger side light blew, I wanted to have a match for the driver side, so I had to stick with OEM. Now the driver side is blown, so I'm gonna have to figure how to get the screws out. Once I do that, I'm going with halogen both sides and new screws.
Sorry for any confusion.
Old Aug 2, 2021 | 08:11 AM
Old School Olds
Amazon Amazon
Old Aug 2, 2021 | 11:11 AM
Oldsdruid
PB Blaster or Kroil and let them sit a few days.
If you have an impact driver it will help loosen a seized headlight ring screw. Alternately if you have a battery operated drill/driver, set it to reverse on low torque and let it hammer the screw loose. Hold it in the screw head tight so it won't strip the Phillips head. If that happens change to a drill bit and drill the screw out.
Old Aug 2, 2021 | 12:07 PM
72455's Avatar
1972 U code Supreme
I like the battery operated drill idea...I'll see how that works and let you know.
brandon reynolds
Nov 29, 2017 02:47 PM
KZ442
Apr 29, 2017 05:06 PM
joesw31
Dec 15, 2013 12:06 PM
Holiday 98
May 15, 2013 09:30 PM
2X72
Mar 23, 2011 02:28 AM
