Iso big block alternator and ps brackets
Old August 21st, 2021 | 04:39 PM
Mj119's Avatar
I have a 455 from a 76 stuck in a 65 cutlass. Trying to get it back on the road. I'm missing the power steering pump, bracket and alternator bracket. I put a small block alternator bracket in there but one bolt hole didn't line up. It was enough to get it started but would like to find some brackets that will take all the bolts. It would be nice to find a power steering pump and bracket too. Please let me know what you have available and what you'd like for it. Thank you.
Old August 21st, 2021 | 08:38 PM
I have done lots of 455 swaps into the 64-67 Abodys, I have used the later p/s pump and bracket with no problems.
As for the lower (I assume?) alternator bracket, you can fabricate a spacer to bridge the gap between the alternator bracket and the power steering pump. Obviously, if you can find the proper 455 brackets that’s preferable. I have used pipe, all thread unions, scrap blocks of steel, whatever.
Old August 21st, 2021 | 09:40 PM
442crzy's Avatar
PM sent
Old August 21st, 2021 | 09:51 PM
Mj119's Avatar
Matt thanks for the tips. I may see what I can cobble together from the junk yard.
Old August 22nd, 2021 | 08:16 AM
newmexguy's Avatar
Have a '70 - '72 type PS pump, small reservoir, with brackets. Other Misc bracketry available, and a three groove crank pulley. Believe to be A body. reasonably clean (rust wise), can ship. Dave S southern NM 88032
Old August 23rd, 2021 | 06:40 AM
tv442's Avatar
Alternator brackets
Hi
do you need alternator brackets for driver side or passenger side of car?
Old March 19th, 2022 | 08:53 AM
FINISHLINE's Avatar
Oops...sorry. just double posted
BSiegPaint
November 29th, 2017 10:51 AM
dshook69
July 23rd, 2017 12:14 PM
ReallyWildStuff
July 20th, 2017 07:45 PM
Rocket1969
February 19th, 2017 02:13 PM
alek72us
March 22nd, 2011 03:13 PM
