ISO bell housing.
Old Jan 2, 2022 | 02:33 PM
coppercutlass's Avatar
Chevy budget Olds powered
ISO bell housing.
I need a bell housing . Can be Chevy pattern or BOP pattern. This will be for a engine run stand so I'm looking for something structurally ok . It will never be in a running car . Would prefer local to the Chicago area. Southern wi , western Indiana .
Old Jan 2, 2022 | 05:34 PM
442crzy's Avatar
I have one here in NJ, I can ship.
Old Jan 2, 2022 | 06:56 PM
69442murph's Avatar
See my post in parts for sale...
thanks
Old Jan 3, 2022 | 01:38 PM
Can you send me a link
Old Jan 3, 2022 | 03:42 PM
RetroRanger's Avatar
72 Olds CS
Link to murphs ad
https://classicoldsmobile.com/forums...emoval-141258/
Old Jan 4, 2022 | 05:38 AM
69442murph's Avatar
Thank you retroranger…
this has been sold…
Old Jan 6, 2022 | 06:10 AM
newmexguy's Avatar
An older car / truck one will be cast iron. Maybe preferable for its intended use?
Old Jan 6, 2022 | 07:32 AM
Whatever works and is available is what I'm after. I have a Ford set up on there with a bell housing and I made the footings and what not. It's home made stand but has been used alot. My olds set up is super sketchy as it was the first thing I had on there lol.
Old Jan 8, 2022 | 09:43 AM
jmcghee's Avatar
willing to ship a
BOP from de
Old Jan 8, 2022 | 09:54 AM
There are no cast iron BOP bellhousings.
Old Jan 8, 2022 | 09:58 AM
Here's a radical thought. If you need both BOP and Chevy, find a blown TH350, TH200, or 200-4R with a unisex case and cut off the bell at the pump. Fabricate whatever brackets you need to mate to your stand.
Old Jan 8, 2022 | 01:07 PM
Joe P I thought about that. I have a few cases here that are no good
Old Jan 9, 2022 | 09:23 AM
ROCKETMAN269V's Avatar
Actually, you can use a Chevy or BOP bellhousing for either engine on a break-in stand, as they both share two common bolt holes. Unless you're going to load the engine, as in a dyno, two bolts should be sufficient to secure the block to the stand. The dowel holes are all in the same location and they take any torque load.
Old Jan 10, 2022 | 05:08 PM
2blu442's Avatar
Or, what do you think about jet boat parts? This is only BOP but it will fit a manual transmission flywheel under it. Aluminum and very thick.
Old Jan 10, 2022 | 05:43 PM
That's exactly what I have for my run stand.
Old Jan 10, 2022 | 06:46 PM
Something like that would be perfect.
Old Jan 10, 2022 | 06:48 PM
jmcghee's Avatar
Joe would you mind posting a pic of your stand?
Old Jan 11, 2022 | 05:52 AM
I ended up making footings. Because it just wasn't gonna be to my advantage to wait to get one or ship one. Thank for the help guys. I do plan on making a sheild for the flex plate area. Along with a few other things like a proper gauge panel and throttle lever. And re mounting the fuel cell. This thing has been. Used alot lol.
Old Jan 14, 2022 | 09:13 PM
oldolds88's Avatar
how about using a multi fit scattershield? i have a couple used ones i can part with resonable.im in mid mi. 5176142324, rob
rpinnt
Feb 16, 2016 06:41 PM
Oldzman71
Feb 13, 2014 04:04 AM
oldspower_68
Mar 23, 2012 02:18 PM
ozoneblue
Jan 23, 2011 05:42 PM
ozoneblue
Aug 21, 2007 05:59 PM
