Hold In Relay & AC Compressor for 70 442
Old Apr 8, 2016 | 05:28 AM
tdhill01's Avatar
Hi, does anyone have a hold in relay for a 70 442 - this mounts on the passenger side fender and/or a original compressor that was rebuilt for r134a? I'm looking to round up the items I need to get my AC back in order.
Thanks,
Tom
Old Apr 8, 2016 | 07:43 AM
oldspackrat's Avatar
Tom I'm about 99% sure I have the hold in relay. I will try to find it later today.
Old Apr 8, 2016 | 08:06 AM
lemoldsnut's Avatar
I am curious what that is and what it is for. Please educate me?
Old Apr 8, 2016 | 11:32 AM
mpolds's Avatar
I have 1 last one -- N.O.S. --
Call me -- Craig -- 516 - 485 - 1935 ... New York.....
Old Apr 8, 2016 | 12:52 PM
tdhill01's Avatar
Scott, thanks for looking and let me know. Mobileparts, if Scott can't find one I'll check out the one you have.
Tom
Old Apr 8, 2016 | 12:55 PM
tdhill01's Avatar
Larry, I don't know myself only that the service manual calls for one - I can read up on it but if someone wants to put it in simpler terms I would appreciate knowing the exact need for it.
Tom
Old Apr 8, 2016 | 01:10 PM
jensenracing77's Avatar
It is a part that should have never been... When you turn on the A/C it will never turn off till the key is turned off and back on. I have the one on my W-30 hooked up correct but I am going to rewire it to turn off when the switch is off. It will only be there to look original. If you only want it to look original it does not need to be a working one.
Old Apr 8, 2016 | 01:16 PM
I checked & I have about 13 other relays but not the AC hold in relay.
Old Apr 8, 2016 | 01:25 PM
tdhill01's Avatar
Thanks, Scott for looking and you too Eric for the explanation.
Old Apr 8, 2016 | 01:27 PM
tdhill01's Avatar
Craig, I just left you a voice mail.
Old Apr 8, 2016 | 02:21 PM
69442C's Avatar
Here is a thread I did on this relay and how to correctly modify it to work like a more modern car. I also show how to use another relay, like a headlight relay, that can be hidden and yet not change the appearance of the equipment under the hood but eliminate the use of the factory relay if it is dead. Keep it there for looks, but the relay function will be elsewhere.
The relay was there for a reason which was to run the compressor when the defroster was used for dehumidification purposes. I also show how to do this too and be able to turn off the compressor through the dash controls.
I'll also look to see if I have a relay as I may.
Brian
https://classicoldsmobile.com/forums...-function.html
Old Apr 8, 2016 | 02:30 PM
69442C's Avatar
I have 2 but I need to see if they work. I'll do that tomorrow. You should follow the information in my thread to make sure yours is really dead and it is not just a bad ground where the coil internally is grounded to the cover. They get rusted sometimes and you lose the ground. Sometimes cleaning it up brings it back to being functional.
Brian
Old Apr 8, 2016 | 03:32 PM
tdhill01's Avatar
Great, thanks Brian - mine was missing from my car.
Tom
Old Apr 8, 2016 | 06:08 PM
66-3X2 442's Avatar
If a 68 uses the same hold in relay,I have a NOS unit still in the GM box for $60 shipped. Contact me @ pchopesq@aol.com
Mike
Old Apr 8, 2016 | 06:11 PM
tdhill01's Avatar
Thanks Mike, I'll see what Brian has and I still need to talk with Craig too - glad to have options.
Old Apr 9, 2016 | 07:03 AM
69442C's Avatar
Tom,
I do have one that works and it also has a nice cover on it. $30 plus shipping which shouldn't be much via USPS.
Brian
Old Apr 9, 2016 | 08:11 AM
tdhill01's Avatar
Hi Brian, I'll take it - I sent you a pm.
Tom
Old Apr 9, 2016 | 08:28 AM
69442C's Avatar
Thanks Tom and I just replied to your PM.
Brian
Old Apr 9, 2016 | 09:38 AM
Yeah, very dumb that you could turn the AC off and the compressor remained engaged. I hated that on my '70 Cutlass so back in the '80s I wired a toggle switch to the relay. Lotsa times on the highway I wanted to turn the AC off without turning the ignition key off.
66-3X2 442
Nov 24, 2023 06:06 PM
pcard
May 14, 2014 01:21 PM
Aron Nance
Sep 28, 2013 07:14 AM
RandyS
Feb 25, 2013 08:07 AM
rsandhoff
Jul 8, 2009 05:23 AM
