Heater Blower Motor '54-'56
Old Jan 14, 2024 | 12:56 PM
madmax442.com's Avatar
madmax442.com
Looking for a blower motor (or a rebuild service), mine works but blows the fuse on Defrost sometimes.
My research is showing a P/N 20-3608 - Blower Motor for 1954-1957 Oldsmobiles and possibly Chevys and others.
https://www.oldairproducts.com/produ...8-blower-motor
Old Jan 14, 2024 | 08:27 PM
deaddds's Avatar
Shoot me a message direct at dead@mchsi.com. Pretty sure Ive got either NOS or NORS.
Old Jan 16, 2024 | 06:25 AM
chopolds's Avatar
I owned a bunch of 55-57 Chevies over the years. I found that a generic blower motor can work on the Chevy heater, by using the old Chevy fan, and maybe drilling a couple different holes. But back then, they would let me go in the back of the store and look through the boxes to get a close match.
Old Jan 16, 2024 | 07:02 AM
redoldsman's Avatar
Proud Viet Nam Veteran
One thing about it, it is easy to change. Good luck.
Old Jan 17, 2024 | 09:24 PM
Love1955oldsmobile's Avatar
An alternate solution to tight heater fan motor
An alternate solution to tight heater fan motor.
If you have a drill the following procedure takes less than two hours and can be done at home
remove the motor from the car. Be careful of motor wires as the insulation is brittle. Heat shrink is a good repair for broken or missing insulation
test the feel of turning the blower wheel.
Remove the blower wheel and mounting plate from the motor
From the bottom side of the motor drill a 1/8 inch hole in the "lumps" on the front and rear of the motor. These "lumps" are the brass bushings that are dry of oil after all these many years
Add 8 to 10 drops of non detergent 20 weight engine oil to each "lump"
Use very short 1/8 set screws with a sealer to seal the holes drilled. may need a tap to make threads to start set screws.
Replace mounting plate and blower wheel
Apply power to motor for 30 seconds.
Test effort to turn blower wheel. Should be much less than initial test of turning blower wheel
Remount on car.
Enjoy
Ron
David7w5
Nov 10, 2022 07:30 AM
JVCCutlass
Nov 4, 2021 08:23 AM
Ultra Tweaker
May 17, 2021 03:17 PM
ChrisInRochester
Jan 14, 2013 09:39 AM
blackcherry
Jul 14, 2010 03:03 AM
