Gas Tank Needed - '27 Model 30e Landau
Tank
Where are you located??
Is there a "Tank-Renu" in your town??
I did have good luck with them locally in Minn.
There is a business that specializes in gas tank and glass for classic cars
Auto City Classics
Isanti mn
may be worth a try??
Cheers
brian
Auto City Classics
Isanti mn
Cheers
brian
Based on the wedding date, I’d suggest a temporary generic tank. You could likely rig up a can safely for the short journey and have the better solution in the queue. Nothing on these older cars is readily available in that short of time (Unless you have a stash of backup parts). I’m also assuming that your trip will be at lower speed and a reasonable short distance. I had the tank renu process applied to my ‘40 Olds nine years ago, zero problems but also not cheap
You'd like it to be as nearly fume-less and safe as possible. Know anyone with an outboard boat engine? Sometimes they have several or at least one you might borrow. If you want to do it yourself, you'll need a fuel line and vented tank - both are readily available. You may need to increase the length of the rubber hose fuel line but I see no reason why you can't rig up a temporary safe application. Several scenarios come to mind.
https://www.amazon.com/attwood-8806LPG2-Certified-gallon-Portable/dp/B0053HOXFI/ref=sr_1_5?_encoding=UTF8&c=ts&dchild=1&keywords=Boat+Engine+Fuel+Tanks&qid=1627509113&s=boating-water-sports&sr=1-5&ts_id=3397801
EDIT: I have no idea why I said Frank - maybe because I replied to Ignachuck earlier.
Last edited by Vintage Chief; July 28th, 2021 at 08:18 PM. Reason: sp: Frank > Glenn
This is their webpage for remote fill tanks and demonstrating the dimensions/sizes. See also their page for direct fill. I don't know which type your car has - direct or remote but I suspect remote.
http://www.rdsaluminum.com/marine-ge...mote-fill.html
Here is a listing of a couple of their tanks from Amazon to give you an idea of pricing. Search Amazon for RDS MFG INC
