Front springs 70 cutlass used
Old Oct 1, 2015 | 08:49 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Hey all need a set of springs shipped to 85737
Old Oct 1, 2015 | 08:59 PM
RetroRanger's Avatar
72 Olds CS
Johnny
i have some 72 350 springs you can have for shipping from mass
but FYI Moog springs from rock auto are $`75 ish shipped
pm if you want the springs
Old Oct 1, 2015 | 09:16 PM
Olds Specialist LOL
sounds good i dont want new ones because they will be too stiff.
do you know what the deal is with them?
how much you think we can get them shipped for?
also do you think i can get them in by just dropping the ball joint? or will they need to be compressed?
John
Johnny
Old Oct 1, 2015 | 09:49 PM
Well that depends upon which springs you get. There are a LOT of different specs springs that will fit the same application, ranging from marshmallow soft to rock hard.
Old Oct 2, 2015 | 05:17 AM
72 Olds CS
When I took them I did not use a compressor.
Ship to LI looks like $18
Old Oct 2, 2015 | 06:59 AM
Olds Specialist LOL
It's arizona 85737
did that car have ac?
sounds good when can you send them?
When I to
Old Oct 2, 2015 | 12:01 PM
72 Olds CS
ship to 85737 from mass is $33 by fedex ship monday or $42 UPS ship saturday LMK if your still interested
yes car had AC
Old Oct 3, 2015 | 06:48 AM
Olds Specialist LOL
I need non AC do you think the car will be too high?
OTE=RetroRanger;862619]ship to 85737 from mass is $33 by fedex ship monday or $42 UPS ship saturday LMK if your still interested
yes car had AC[/QUOTE]
Old Oct 3, 2015 | 06:57 AM
72 Olds CS
Hard to say how it will be on your car but I changed them out because the car was low in front w these springs
Old Oct 3, 2015 | 07:06 AM
Olds Specialist LOL
Mine are wasted, wondering if I should just get the stock height ones, but I also want an easy install so used ones might be the way to go! Hmm??
OTE=RetroRanger;862801]Hard to say how it will be on your car but I changed them out because the car was low in front w these springs[/QUOTE]
Old Oct 3, 2015 | 11:03 AM
AzChevs's Avatar
I live in Glendale and have a few sets to choose from, also another lot in Sierra Vista 65 miles southwest of Tucson that has more. Just in case your not sure, price would be $30.00 pair.
Old Oct 3, 2015 | 11:08 AM
lemoldsnut's Avatar
To do them easily you need to unbolt the sway bar links, the lower ball joints and outer tie rods, remove front shocks. Of course the normal jack up the car put it on safe jack stands and then use a spring compressor and when you put it back together you will have to use a floor jack or similar to jack up the lower control arms to reconnect the ball joints. It is about a 2-3 hour job, If you don't have all the tools some can be borrowed or rented at many parts stores. If you were local I would help you. I wonder if someone on this site is close that can help you?
Due to the amount of work I really recommend new springs. I also recommend an alignment be done after.
hope this helps
Larry
Old Oct 3, 2015 | 06:55 PM
Olds Specialist LOL
spring shot collapse
shot of spring collapsed
Old Oct 3, 2015 | 11:44 PM
Olds Specialist LOL
For the three extra bucks id rather just get the ones from retro thanks~
thanks CO! got them
Old Oct 10, 2015 | 02:03 PM
Olds Specialist LOL
Spring install WHEW!!!
Well the springs are done!
looks like a good height as expected , No spring compressor needed.
that spring was Toast!
just brute strenth and leverage!
rcktdoc
Nov 13, 2013 03:04 AM
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
1acesmith
Aug 11, 2011 11:03 AM
oldsconv
Aug 3, 2008 12:03 PM
