Factory Piston 69 Olds 350 (High Compression)
Old Feb 15, 2018 | 07:50 PM
69 Vert's Avatar
Rebuilding my 350 pulled out pistons and found 1 with a broken skirt
Looking for 1 Factory piston do not need the rod.
Got lucky with no damage.
Old Feb 16, 2018 | 03:56 AM
ROCKETMAN269V's Avatar
Is it an "A", "B", "C", or "D"? Look on the deck surface of the block; there should be a letter stamped next to each cylinder, indicating the "relative" size of the piston. These were referred to as "select fit" engines. Thanks, Bob.
Old Feb 16, 2018 | 09:09 AM
69 Vert's Avatar
Thanks for responding
It is a “C” only found 1 stamp on block it is by #8 piston
1970supremevert
Jan 25, 2014 05:24 AM
mcalvo
Dec 12, 2013 09:34 AM
dkraus71cutlass
Apr 1, 2011 09:34 PM
69Rman
Mar 27, 2010 10:22 AM
