Factory Piston 69 Olds 350 (High Compression)
Rebuilding my 350 pulled out pistons and found 1 with a broken skirt
Looking for 1 Factory piston do not need the rod.
Got lucky with no damage.
Is it an "A", "B", "C", or "D"? Look on the deck surface of the block; there should be a letter stamped next to each cylinder, indicating the "relative" size of the piston. These were referred to as "select fit" engines. Thanks, Bob.
mcalvo
December 12th, 2013 09:34 AM
cts-v
January 10th, 2009 04:55 PM
