Crank pulley
Old July 4th, 2013 | 04:24 AM
Stevec's Avatar
Crank pulley
Looking for a crank pulley for a 68 400 engine or if anyone knows where I can get an after market one that is as close to the originals diameter?
Old July 4th, 2013 | 06:16 AM
tru-blue 442's Avatar
Old School Olds
Steve, 2 or 3 groove?
I may have something you can use.
Old July 4th, 2013 | 06:36 AM
Stevec's Avatar
2 groove...
Old July 4th, 2013 | 07:57 AM
Old School Olds
Steve, I found 5 of them.
Unfortunatly all are 3 groove.
I guess that must be the difference
between CT and TX. We gotta have our a/c.
Good luck with the search.
Old July 4th, 2013 | 08:11 AM
MI68442W30's Avatar
that would be a KB code crank pulley you need for a 68 non air [2 groove]. it's possible I may have an extra but will take me a while to search through my parts too see.
Old July 4th, 2013 | 10:30 AM
Octania's Avatar
I have a spare rusty MI unit if you can live with an imperfect one.
C 2 KB 399402 6.50 dia 2.20 overall width
Beware the other "KB" 3 groove.
God forbid they use one of the other hundreds of 2-letter combinations for a different pulley.
Old July 4th, 2013 | 03:12 PM
Stevec's Avatar
How about this set?
Email to a Friend
Be the first to review this product
Availability: In stock
$299.00
Quick Overview
Billet Pulley set for 68-74 Olds 350 & 455 using 5.6 length water pump. Our billet 6061-T6 alum pulleys feature deep, aggressive grooves for capturing belts. We use original factory contours so that in black hard-coat they look dead-on original. If you prefer, polished with our clear-ceramic coat will bring a clean, custom touch to the front of your mill! Much stronger & true-er than stamped steel pulleys!
Don't confuse our products with the inferior lego-design import pulleys. Fit, strength and function is our specialty. Set includes correct dia. 2gr crank, 2gr water pump, p/s and alternator pulleys.
Select finsh below:
*Finish
* Required Fields
$299.00
Qty:
Add to Cart
Add to Wishlist | Add to Compare
Double click on above image to view full picture
MORE VIEWS
Old July 4th, 2013 | 03:15 PM
Stevec's Avatar
That was from ram air restoration ent,inc. I know it's a bit pricy,has anyone have any experience with them?
Old July 4th, 2013 | 04:26 PM
Octania's Avatar
http://www.ramairrestoration.com/pso...-ps-no-ac.html
Old July 4th, 2013 | 04:38 PM
Stevec's Avatar
Hey Octania are you familiar with that set? What do you think? Ill have to drill the crank pulley to fit the ati balancer.
Old July 4th, 2013 | 06:48 PM
slaughter442's Avatar
KB Pulley
Steve we have one it nice no rust If We Can Help Let Us Know Thanks Darren
Old July 8th, 2013 | 08:34 PM
Octania's Avatar
I am not familiar with the pretty new parts, no... just put a handy LINK here so's folks can be on the same page in the discussion.
s-laughter's pulley looks REAL GOOD though.
ha ha ha
s... laughter
WTony
October 3rd, 2009 05:56 PM
TOOhep
March 28th, 2009 12:33 PM
J-(Chicago)
December 7th, 2007 05:10 PM
Droptop
July 7th, 2007 07:16 PM
Droptop
July 7th, 2007 07:10 PM
