Correct Carb Needed
Old Sep 12, 2018 | 09:19 AM
Tom Bilse's Avatar
Correct Carb Needed
I'm having a '69 H/O restored (original engine, intake, etc.).
The # on the carb I have is 7028251. The correct carb # is 7029251.
I've been informed the correct carb was available on '69 455 4bbl engines and was not exclusive to the '69 H/O.
Thus I'm on a quest to find a correct carb. The build date of my car is the 4th week of May.
If anyone has a such an item, please advise.
Once I've obtained it, if anyone is interested in my carb (in fact I have 2 of them), let me know.
Thanks.
Old Sep 12, 2018 | 12:57 PM
rcorrigan5's Avatar
Randy C.
The 7029251 carb is the correct carb for your '69 H/O. The "9" in the carb part number means it is for a model year 1969 Oldsmobile. The "8" in the carb you have is for a model year 1968 Olds H/O with A/C and the '68 4-4-2 (excluding the W-30) with an automatic transmission. If you find a 7029251 carb, you should be able to sell your 7028251 carb for about the same price you pay for a 7029251 carb.
The 7029251 carb was used on the '69 H/O (both manual and automatic transmissions) as well as the '69 4-4-2 with automatic transmissions (excluding the W-30 and W-32 variants).
Randy C.
Last edited by rcorrigan5; Sep 12, 2018 at 01:01 PM. Reason: adjust wording a bit and add sentence about cost
Old Sep 12, 2018 | 01:01 PM
ROCKETMAN269V's Avatar
Re-read the post
Old Sep 12, 2018 | 04:04 PM
Tom Bilse's Avatar
I think I was too wordy on my initial post (bad habit of mine) :-(.
As ROCKETMAN269V noted, I'm needing the 7029251 carb.
rcorrigan5, thanks for your post, which confirms my understanding.
Old Sep 12, 2018 | 04:59 PM
To clarify, 7029251 was used on all RWD 455 motors (ST and AT), plus all non-W 400 AT motors in the 1969 model year. There are a boatload of these out there, since every Delta and Ninety Eight with a 455 4bbl motor came with a '251 carb.
Old Sep 12, 2018 | 05:27 PM
tru-blue 442's Avatar
Old School Olds
I have a core if you want it. The bottom plate is stuck. Inlet threads are excellent.
Old Sep 12, 2018 | 07:54 PM
Quadrajet Power's Avatar
We have some 7029251 available for restoration.
Old Sep 13, 2018 | 05:03 AM
jollyolds's Avatar
pm sent
Old Sep 13, 2018 | 03:34 PM
Tom Bilse's Avatar
Thanks for the great input and advice.
I've posted a close-up photo of the # on each carb in the "Major Builds" section.
It's interesting one has "1068" and the other has "RJ" next to the carb #.
Old Sep 14, 2018 | 06:28 AM
jollyolds's Avatar
the 106 8 is the date-the rj refers to the plant it was built at-did u get my pm?
Old Sep 14, 2018 | 09:21 AM
Tom Bilse's Avatar
jollolds, I did receive your pm. Thanks.
Old Sep 25, 2018 | 10:12 AM
Tom Bilse's Avatar
Carburetor Found
This is to advise I have found a good/correct carb for my H/O.
Thanks to all who've provided help related to this. I've learned a lot during this process.
Oldzman71
Jun 23, 2018 02:34 PM
tru-blue 442
Jun 13, 2017 09:51 PM
John1963
Jul 20, 2012 02:29 PM
benji94
Nov 8, 2010 08:11 PM
