Bulb Holder
Bulb Holder
Need the bulb holder for the turn signal indicator in the gauge cluster. it's white and apparently holds a 194 bulb that lights to indicate the turn signal is on. don't imagine they are side specific, but if so, need the right one. thanx.
I have been collecting sockets for a while now for all the gauges that I restore and there are at least two different styles of those sockets. Could you get a picture of the front and the back of it to make sure we get you the right one? If so I probably have one for you.
wow, never got any e-mail notification of you guys's answers!! Thanx for answering!!! I have gotten some aftermarket ones that don't fit. this one I have is white. I will take the one out and take a picture of it. I bought one bag of 25, didn't fit and the NAPA ones don't fit either. it is a 1/2" socket for the 194 bulb but the ones I got don't screw in at all. I am wondering if the missing bulb, not only doesn't allow the turn signal indicator to work, but also the side that doesn't have the bulb in...when you turn that turn signal on, and you have the brake pedal depressed, as soon as you have both on at the same time, it knocks off the brake lights. I figure that the circuit isn't complete without the bulb holder in there.
The brake lights work fine on both sides with the turn signal off. when the turn signal that has the blinker indicator installed....the other side, when the blinker is off, knocks off the brake lights. I switched it back and forth with the one blinker light socket i have and it does it each time. the side with the blinker in, the brake light on the other side stays on. the turn signal that is on without the blinker installed, then it knocks out the brake light on the other side.
The break lights work fine on both sides with the turn signal off. when the turn signal that has the blinker indicator installed....the other side, when the blinker is off, knocks off the brake lights. I switched it back and forth with the one blinker light socket i have and it does it each time. the side with the blinker in, the brake light on the other side stays on. the turn signal that is on without the blinker installed, then it knocks out the brake light on the other side.
sorry, will try to explain again...also, I am in the Tampa Bay area.
ok, for example, if I have the blinker socket in the dash plugged in for the right blinker and the brake lights are on, then turn the right turn signal on, then the brake light on the left side stays on. if you turn the left turn signal on, then the turn signal works, but the brake light on the right side goes out. If I switch the dash blinker socket to the left side, the opposite happens. then with the brakes on, turn the left turn signal on, then the brakes stay on, turn the right turn signal on, then the brakes go out. so whichever side I have the blinker socket in for the dash blinker light, the opposite side turn signal turns the brake light off. hope that is a better explanation.
oldzy
December 14th, 2010 06:47 AM
