Brass external water bypass fitting for 303
Old Jan 4, 2021 | 09:24 AM
maineolds's Avatar
Looking for a replacement for my broken brass external water bypass fitting for 303. This screws into the front timing cover. It looks like an elbow fitting with 3/8 NPT female to 1/4 NPT male. Tricky thing is it has a flare inside the 3/8 section to seal the water pipe. Here’s pictures:
Old Jan 4, 2021 | 10:56 AM
ROCKETMAN269V's Avatar
That would appear to be an inverted flare female fitting, not a pipe thread.
Old Jan 4, 2021 | 10:58 AM
maineolds's Avatar
Thank you! If I have to find one some other way, it will help to know exactly what I’m looking for. I’m hoping to find the original. I can’t seem to find anything that works at local hardware or plumbing supply companies. Even the internet is drawing a blank.
Old Jan 4, 2021 | 11:00 AM
What size is the metal line that attaches to the female side? Thanks, Bob.
Old Jan 4, 2021 | 11:17 AM
maineolds's Avatar
3/8”. I MAY have found a replacement. Made my Hillman. Part number 58343. I found one on Amazon. Not much info. Fingers crossed it’s what I need.
Old Jan 4, 2021 | 11:43 AM
rocketraider's Avatar
Oldsdruid
Looks very similar to a fitting Olds used on 65-66 a/c-equipped big car transmission cooler lines at radiator end. We had a hell of a time finding one for a 66 Starfire nearly 20 years ago.
Old Jan 4, 2021 | 06:16 PM
Loaded68W34's Avatar
Should be the same as a BBC fuel pump fitting
https://www.ebay.com/itm/Corvette-Fu...YAAOSwq4tfOBK-
Old Jan 4, 2021 | 06:21 PM
maineolds's Avatar
Awesome! If the part I bought on Amazon doesn’t work I’ll grab one of those
Old Jan 7, 2021 | 04:36 PM
maineolds's Avatar
Amazon came through! I can confirm a part made by Hillman, part number 58343 is a perfect replacement.
Old Jan 8, 2021 | 04:29 AM
Great! Glad that you found what you needed.
Hairy Olds
Dec 17, 2021 06:05 PM
w30brad
Oct 11, 2020 04:03 PM
w30brad
Sep 17, 2020 05:02 PM
twiggy
Oct 23, 2017 05:33 PM
virtualwsp
Mar 24, 2015 06:50 AM
