Battery cable tube
Old Sep 28, 2011 | 10:00 AM
zodiacblueS's Avatar
Battery cable tube
Looking for battery cable heat protection tube, mounts on frame where battery cable nears exhaust manifold. Prefer 5" but will take either version. Thanks.
Old Sep 28, 2011 | 11:12 AM
Tom442's Avatar
I have an extra and I am in Denver if you are interested!
tom
68 442 convt (gotta get it fired up)
70 F85
95 Aurora
Old Sep 28, 2011 | 12:23 PM
Battery cable tube.
PM sent. Got it. Thanks!
Old Sep 28, 2011 | 07:00 PM
501Paratrooper's Avatar
Anyone else have one I need one too, for an A/T
Old Sep 28, 2011 | 09:01 PM
oldspackrat's Avatar
I've got a few in stock, give me a call & leave your info if I can't answer.
Thanks.
Scott
c. 317-727-7041
Old Sep 29, 2011 | 05:14 AM
ROCKETMAN269V's Avatar
Smile Battery cable tube
I have several; I'm in Deerfield Beach. Give me a call: 954-428-8795, mon-sat, 8-4. Thanks, Bob.
Old Sep 29, 2011 | 07:14 PM
507OLDS's Avatar
I have a whole box,with or without bracket.
Old Oct 9, 2011 | 04:41 PM
OK, I got a nice one from Bob ROCKETMAN269V but I'm having a hard time finding the right bolt for the hole?? I tried a 5/16 hex head self tapping and it didn't work, did the original use a nut?
Old Oct 9, 2011 | 04:42 PM
Bob, the tube cleaned up nice thanks!!
Old Oct 9, 2011 | 04:51 PM
2blu442's Avatar
The bolt did not use a nut. But some holes used coarse thread vs the fine thread. You might check that before cutting it out to a 3/8" sized bolt. John
Old Oct 10, 2011 | 05:19 AM
507OLDS's Avatar
Some of those frame bolts were a coarse sheetmetal style bolt,about 1/2 long with a pointed tip.Not a machined thread.
Old Oct 10, 2011 | 02:13 PM
70Post's Avatar
See pic below....it definitely uses a 5/16" bolt. All of them that I have use a regular threaded (ie machine thread) bolt to hold the battery cable tube "plate" to the frame. Sure, it doesn't make any sense since this was just a hole without any threads or a nut, etc to hold the bolt but that's what I have found on the many battery cable tube setups I have pulled over the years. Typically it's a flat tipped bolt as well. A coarse threaded and pointed 5/16" bolt would probably work as well.
If you want to get really ridiculous...the typical head marking on this bolt always seems to be a crudely hand drawn "T M" (with the "T" being on top of the "M"). Probably more than you wanted to know but "when in Rome...."
Should not be any need to go to a larger size bolt unless the hole has been wallowed out.
Old Oct 10, 2011 | 02:55 PM
2blu442's Avatar
There may have been different fasteners used, so you might have to experiment a little to find the right one. I just pulled this one from a 1971 Cutlass parts car, it required a 1/2" wrench and this is the coarse threads I was trying to describe. I think this may also be what Brian was describing too. John
Old Oct 10, 2011 | 04:56 PM
Thanks guy's yes it's a 5/16. I had to go to a Bolt and Fastener place and had to buy a 100 @ 10 bucks 5/16 hex head self tapping bolts, and they still didn't work!@!#. I checked the brake distribution block and it is the same bolt worked perfect, so I looked for them and couldn't find any!!!
I called InlineTube and they had it, has an anchor on top.
So the damage was 6 for 9 bucks oh well.
Thanks for all the help everyone, I feel bad just for a stupid battery tube!
70Post
Aug 15, 2015 08:31 AM
rcktdoc
Oct 14, 2014 03:50 PM
AzMotorhead
Apr 15, 2013 06:49 AM
ErikW
Mar 25, 2013 12:35 PM
Gary's 2 442-S
Dec 15, 2009 05:25 AM
