Alternator brackets and pulleys.
Old Apr 17, 2024 | 10:03 AM
Mr. Rocket's Avatar
Looking for complete set alternator brackets for a 69 350 non A/C. Also need water pump and crank pulley for non A/C engine.
In Pittsburgh Pa.
Thank you!
Old Apr 17, 2024 | 10:16 AM
11971four4two's Avatar
MOTORHEAD
https://classicoldsmobile.com/forums/parts-sale-11/two-groove-water-pump-pulley-kn-15
I have two groove pulleys
Ad with pictures in For Sale Arena
Old Apr 17, 2024 | 10:51 AM
70Post's Avatar
In Pittsburgh Pa.
Thank you!
Do you happen to know the part numbers or pulley codes (two letters) for the two pulleys you need? That info would be in a '69 Assembly Manual (PIM/Product Information Manual).....at the beginning of Section 6 (the Engine section....drawings depicting various belt, pulley, etc combinations).
Old Apr 17, 2024 | 10:54 AM
Mr. Rocket's Avatar
I do not know the part numbers. Would the water pump dictate that?
Old Apr 17, 2024 | 11:00 AM
Mr. Rocket's Avatar
Thank you, no reason why those wouldn't work for a '69 ?
Old Apr 17, 2024 | 11:23 AM
70Post's Avatar
Depends what you're trying to achieve. If you want the correct sized/original pulleys for your car then yes, the PN and/or two letter codes matter. Once you start changing water pump lengths, etc away from what your car had originally, all bets are off.
Thus my question about checking the PIM....that will have the correct/original info for you (if it matters).
Another reason I ask is I think I may have a pair of pulleys I pulled from a NON-AC '69 Cutlass many years ago.....likely original and correct to the car I pulled them from. I don't know which codes/PN's to look for in my stash for the '69 stuff.
Old Apr 17, 2024 | 12:34 PM
VI Cutty's Avatar
There are a number of threads in the forum with information on pulley ID and which ones work together. Water pump length determines which pump pulley you'll need. Crank and pump pulley need to be matched as well - in 70 or 71 the pulley diameters changed so mismatched pulleys won't work together even with the "right" offset. Pulleys are marked with two letter codes...knowing those will help.
I'm afraid I don't have that info close to hand or I'd post it for you.
Old Apr 17, 2024 | 12:42 PM
oldschool85's Avatar
PM Sent
Old Apr 18, 2024 | 09:15 AM
Mr. Rocket's Avatar
Gentlemen, thank you for the feedback. I'm not concerned about correct part numbers just looking for parts that will work together. Couple guys PMd me with parts they have and will get me straightened out.
Old Apr 18, 2024 | 10:54 AM
v8al's Avatar
Registered Olds Owner
Do your homework or you are going to be buying parts that don't work together.
Things to watch out for:
  1. Determine what water pump length you need. There are three different sizes: 5.1", 5.6", and 6".
  2. Water pump inlet diameter varies 70 and earlier are 2". 71 and up are 1.75".
  3. Radiator outlet nipple sizes vary between 1.5" and 1.75"
  4. Lower radiator hoses are only available in certain combinations. If you have a mismatch you will need to use a rubber sleeve to shim the hose to the correct size.
  5. Bigger 4 core radiators require larger lower radiator saddles and a different top plate. (unless you car was originally equipped with a 4 core)
Also you should determine if you are going to run a clutch fan or a radiator shroud.
Good luck!
Old Apr 18, 2024 | 11:06 AM
Mr. Rocket's Avatar
  5. Bigger 4 core radiators require larger lower radiator saddles and a different top plate. (unless you care was originally equipped with a 4 core)
Good luck!
Thank you! All very good information most of which I wasn't aware of.
Old Apr 20, 2024 | 07:18 PM
442crzy's Avatar
PM sent
Old Apr 21, 2024 | 05:29 AM
Mr. Rocket's Avatar
Located parts I needed. Thanks again
user 7408240824
Jul 9, 2018 05:20 AM
lemoldsnut
Sep 18, 2014 10:12 AM
QS442
Jun 27, 2014 05:07 PM
QS442
Nov 23, 2013 07:45 PM
STR-8_CHARGIN
Aug 13, 2010 04:25 PM
