Alternator bracket
Old Mar 9, 2014 | 07:51 AM
70cutty's Avatar
Beer Connoisseur
Alternator bracket
I am looking for a passenger side alternator bracket for a 307.
Old Mar 9, 2014 | 12:27 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You can find these setups on 65-67 425 engines, and 68-70 455 engines. Usually the cars without air conditioning.
Toronado stuff is different, so avoid those.
You will also need a short water pump from a 425 engine, and the correct pulleys.
It's usually a $200-300 expense for this conversion once you track down and buy everything you need, from my experience.
It's much easier and cheaper to use a 72-76 driver's side bracket and pulley setup, even if it's a little uglier looking.
Old Mar 9, 2014 | 12:44 PM
66-3X2 442's Avatar
I have a complete passenger/right side alternator bracket assy. for sale. It's better to contact me by email @ pchopesq@aol.com
Mike
Old Mar 9, 2014 | 03:21 PM
crazy'boutOlds's Avatar
I also have a set
Old Mar 10, 2014 | 07:51 AM
70cutty's Avatar
Beer Connoisseur
I apologize I made a mistake when describing the bracket, in the picture is what I was looking for. I got a hold of the upper, is there a lower bracket for this and does anybody got one.
http://www.flickr.com/photos/78185943@N03/13061302514/http://www.flickr.com/photos/78185943@N03/13061302514/ by http://www.flickr.com/people/78185943@N03/, on Flickr
Old Mar 10, 2014 | 08:27 AM
jcdynamic88's Avatar
alt bracket
the other half is the adjuster bracket that bolts to the p/s pump and exhaust manifold bolt,this setup doesn't go on passenger side of motor,driver's side. I probably have one,year of car would be helpful
Old Mar 10, 2014 | 08:33 AM
70cutty's Avatar
Beer Connoisseur
Thanks, I realized that after I posted.
I am trying to set it up on my 70 cutlass. If you have one let me know how much you want for it.
Old Mar 10, 2014 | 11:28 AM
alt bracket
I have the adjuster bracket $20 plus ship,i'm in mass that's a long way to go.there's got to be plenty of these out there.the 307 y motor was used in so many cars.if you are using this set up on a big block you will need a spacer between the p/s pump and adjuster bracket.i also think this style bracket is for a larger alternator than what came on your cutlass
Old Mar 10, 2014 | 12:59 PM
70cutty's Avatar
Beer Connoisseur
Thanks, unfortunately it would cost me more money to drive to a junk yard than to get it from you. PM Sent
Old Mar 12, 2014 | 10:30 AM
$_3 by 70cutty, on Flickr
This is a DRIVER'S SIDE alternator bracket, not a passenger side bracket. The 307 never came with a passenger side bracket.
442mark
Sep 30, 2017 01:06 PM
xerxes600rr
Aug 30, 2011 06:43 AM
cisco88
Cars Wanted
Mar 1, 2008 09:47 PM
Natas
Nov 24, 2007 06:07 PM
Natas
Nov 15, 2007 05:42 PM
