77 Cutlass Brougham Rebirth need drivers side exhaust manifold
Old Sep 29, 2015 | 09:32 AM
Paul Owen's Avatar
Hello,
I bought a 77 Cutlass last year that had been stored in a polebarn since 94. 56,000 original miles very nice shape. 350 4barrel runs great. I have worked out most of the bugs and now am needing a driver's side exhaust manifold. I had a muffler shop install a new exhaust system and was told that the driver's side exhaust manifold has a crack. My mechanic and I checked it out and found this to be the case. I know how much effort it can be to remove the original to replace so he will tackle that one. Problem is that I need to locate one for replacement. The muffler shop said that there were several different types used on Olds Cutlass for that year ,but I can't seem to verify that. Several people said to just leave it, but I want to quiet it down and keep it stock. Any info would be greatly appreciated! Paul Owen
Old Sep 29, 2015 | 11:12 AM
Welcome to the site, add your location. I moved your post to the parts wanted section, hopefully someone has one close to you. As long as the bolts aren't too corroded, it should pop right off.
Old Sep 29, 2015 | 04:27 PM
76olds's Avatar
Hookers under Hood
If you can't find one soon;
Prior to installing the headers on my 76 I had a manifold leak on the drivers side as well. I'm fortunate to work in a Tool and Die shop and have .001 all the way up to .05 shim stock. I cut a few pieces of .005 shim ( just need a good pair of scissors) then pushed them into the thin crack (engine cold) and bent the excess over the manifold. It worked until I put the headers in.
Hope this helps
Eric
Old Sep 30, 2015 | 03:21 AM
Paul Owen's Avatar
I am looking on line. Are there any companies or sites anyone would recommend?
Old Sep 30, 2015 | 04:33 AM
ROCKETMAN269V's Avatar
Smile 77 Cutlass driver's side exhaust manifold
I have several down here in sunny South Florida. Email me for pics, etc.: drolds1@bellsouth.net. Thanks, Bob.
Old Sep 30, 2015 | 12:43 PM
Cutty77's Avatar
I have 2 in central Illinois.
Old Oct 1, 2015 | 07:31 AM
442fanatic's Avatar
Thornton's reproduce manifolds for Olds 455s and olds 350s for the good years which still fit the smoggers. Though my car fits in the smogger years, no components will ya see of that under the hood on the newly built olds 455.
Old Oct 3, 2015 | 12:02 PM
PACE77's Avatar
403
Do you know if they make them for a Olds 403 ?
Old Oct 3, 2015 | 03:37 PM
Cutty77's Avatar
They probably do, but I'm not positive. You would have to check their site. I think I have close to $800 in my system and installed it myself. Had to do some fab on it to get it to work. Not many options for 77 so I used a 73 system.
Old Oct 15, 2015 | 09:39 AM
Paul Owen's Avatar
Finally got the exhaust manifold. Arrived last Saturday, but with our unique Postmaster and her interesting ways it wasn't until today after my complaining that she came up with a mysterious package. Oh well. Big thanks to Ron!
Doug Sander
Apr 27, 2011 07:13 AM
eddieunderground
Jan 11, 2011 04:00 PM
eddieunderground
Oct 9, 2010 11:22 AM
dallasite21
Feb 17, 2010 07:22 AM
KQQLCAT
Apr 1, 2009 05:34 AM
