76 cutlass supreme brougham
Hi all.....looking for various parts to restore my sons great grandpa's Cutlass.
Message me if you have a rear bumper, or exterior window trim for a 76/77 cutlass supreme.....thank you!
Window trim 77 cutlass
I have the trim you are looking for but it is not complete and they are not with me. I have them in storage in Lubbock TX at my mothers. Ill get them next time I visit. I have a question for anyone out there. I need a vacuum line diagram for a 77 cutlass salon 350. I am having trouble with my cutlass. The lines were all taken off when I bought the car. Please help!! The car seems to want to die out when I pull up to a street light, then it seems fine when I get going again. However, when I am on the highway and if I step on the accelerator too fast it will also want to bog out as if it is getting flooded. I am pretty sure i am running too rich as well because the smell of gas is pretty strong under the hood. Also,sometimes when i Turn the car off after driving around, it wants to stay running even though the key has been taken out of the ignition. Again I might even need to set the timing i don't know. I've played with the distributor turning it back and forth to try and get the car to idle good but i am clueless on howto do this correctly. Do I need a timing light? Please Help
Response to Needed Help
To the last post with the driveability problem; you would get much better results if you were to post your concern in the appropriate tech forum.
You can find the vacuum diagram in the correct Olds service manual for your car. eBay is the first resource I think of for one of them, but they should be readily available from other sources.
Wildcard
Nov 29, 2012 08:52 PM
69Rman
Mar 16, 2009 05:40 PM
POKANOKET
Jul 14, 2007 02:58 PM
