73-77 T-top Interior Trim
Old Aug 24, 2018 | 02:53 PM
88hurstolds's Avatar
www.gbodyolds.com
Looking for the interior t-top trim that does on the A pillars for 73-77 Cutlass
Old Aug 28, 2018 | 06:44 PM
crimsoncolby's Avatar
Any luck finding these pcs? There was a Grand Prix w/t-tops being parted at a local JY that I could check out for you. This generation of GM "A" bodies shared a lot of interior headliner pcs and I'd be willing to bet they would be the same on all t-top cars.
Old Aug 28, 2018 | 07:30 PM
oldolds88's Avatar
just a caution, there were different t tops installed 73- 77 and on the g bodies. factory and after market are different in most every way.in 76 77 independent shops installed some,cars and concepts had another brand,ive got the name in my file. hurst hatch is different than factory t's. look carefully
Old Aug 28, 2018 | 08:27 PM
It's true that not all t-tops on the '73-'77's were factory or Hurst. Plus, there were first and second generation Hurst designs used as I understand it. Thus, I wonder if the shops that installed these simply cut the standard headliner trims to fit...or, was there a GM part number for a special trim that the shops also used for their installations?
Old Aug 29, 2018 | 05:49 PM
first77's Avatar
First and second gen hurst A pillar plastics are the same - cutting non ttop cars is the easiest to get these , the only difference is a second hole for a screw with a boss on the back side.
File Type: jpeg
Old Aug 29, 2018 | 07:30 PM
Looks like there are GM part numbers on the backsides. Are you able to post these so I could compare to what I find on the Grand Prix? Info might be of value to someone down the line.
Old Aug 30, 2018 | 04:40 PM
first77's Avatar
Part #'s
Actual trim not easy to get at - attached are schematic with part #'s for hurst gen 1 ttops
gen 2 had same # listed , I confirmed for a pillar plastic
gen 3 kits did not come with A pillar trim - gen3 was a recall kit made in 1979 when installed the a pillar plastic was reused.
File Type: jpeg
Old Aug 30, 2018 | 04:42 PM
first77's Avatar
Part #'s
Part #'s
File Type: jpeg
Old Sep 1, 2018 | 09:56 AM
Good info! Appears the O.P. has moved on, but it's good to have this documented on this site for the next person who needs help.
Was going to run out to the JY to check on the GP trims to see if the part numbers matched up, but they are closed for the Holiday weekend. Hopefully, they won't crush it before I can get back there.
Lnirkum
Nov 5, 2016 07:23 PM
brianstrange
Feb 27, 2016 02:22 PM
brownbomber77
May 29, 2012 09:06 PM
jensenracing77
Apr 5, 2011 06:55 AM
Kenneth
Jun 27, 2008 01:40 PM
