70 71 72 rear convert upper door panels
Old Jan 4, 2011 | 08:19 PM
sx455raidercelticfan's Avatar
hi i need some rear convertable upper door panels for a 70 71 or 72 cutlass, legandary dosnt make them and i need them b4 i order my int, they must be convert panels and i will pay extra!! no low balln!! i need them asap!!!!!!!!! thanks
Old Jan 5, 2011 | 05:10 AM
Lady72nRob71's Avatar
Which panels are you referring to?
The rear quarter panels?
If these are the ones, Legendary makes them!
Old Jan 5, 2011 | 08:52 PM
those are the exact 1s i need!!! i just talked 2 i think his name was scott at leganday and tried 2 order my int but he said that i had 2 send in my rear door panels because they dont carry the rear upper molds for convertables only hard tops!! the part i need is the upper medal or plastic molded part that goes behind the material its the part that the weatherstriping staples 2, did you have 2 send in your panels?? if not ill buy your old 1s for 200 plus shipping???
Old Jan 6, 2011 | 02:30 AM
jensenracing77's Avatar
if all you need is the upper part, i may have a set. these are from 70 and the top molded part is fiberglass. if this is what you need send me a PM and i will get you pictures.
Old Jan 6, 2011 | 05:19 AM
You are right. They sell the visible panels but the plastic / fibreglass upper "rails" are unavailable. Legendary took my old rails off my old panels and put them on the new panels and sent everything back. The picture above was how it turned out.
I do not have an extra set of 'rails' but it looks like Jensen does!
Old Jan 6, 2011 | 03:32 PM
there are a couple cracks and a couple small chipped corners. i figure they can be fixed/used but i know nothing about this kind of work. all cracks and both chips are in the pictures. if they are something you can use let me know. i have zero idea of there value. i was never into convertibles much. if you need higher resolution pics i can e mail them to you.
100_0148.jpg?t=1294355947
100_0145.jpg?t=1294356188
100_0144.jpg?t=1294356221
100_0143.jpg?t=1294356279
100_0141.jpg?t=1294356311
Old Jan 6, 2011 | 05:35 PM
pm sent
Old Jan 6, 2011 | 09:28 PM
Olds24's Avatar
I have a nice pair of uppers if you still need them.
Old Jan 7, 2011 | 05:28 AM
My uppers had similar minor damage but did not affect installation. I think you could use these. Perhaps some epoxy can be used to fill in the cracks.
Old Jan 8, 2011 | 02:43 PM
thanks but i allready bought the1s pictured so im good 2 go, if something goes complety wrong ill shoot you a email, thank you
your right rob those look very fixable, ill fiberglass them and build that corner up, and once there installed they wont come off for 10 years
Old Jan 8, 2011 | 04:44 PM
we jeep inn's Avatar
Mine looked similar those when I pulled them out. A little fiberglass mat, resin and trimming fixed 'em right up. Sent them to Legendary to build the panels, worth the extra $ IMO.
Good luck
Old Jan 9, 2011 | 01:07 PM
Good luck
thank you
bigdooly
Mar 1, 2015 05:35 AM
75JAW
Jun 2, 2014 06:47 PM
eudaman
May 19, 2013 05:30 PM
chris83
May 25, 2010 02:58 PM
chuck2
Jan 12, 2005 02:11 PM
