'70 442 Parking Brake Lever
Once again calling on the guru's.....Does the parking brake lever assembly differ from one without the warning switch that let's you know your parking brake is on?
The brown wire from the harness is there ( and works the red brake warning light come on in the cluster when power is applied? I have a NOS OEM switch but....the lever assembly in my car does not have a hole to mount the switch.
As always...... Thanks in Advance !
DRXOLDS
DRXOLDS
DRXOLDS
DRXOLDS
(It's early in the morning and I've not finished my coffee, but I believe the above info to be correct...and if not, someone is sure to correct me.)
Kilmster
Brakes/Hydraulic Systems
August 6th, 2014 05:41 PM
nanardos
September 12th, 2013 12:28 PM
