69 442 Door Parts
Old Aug 23, 2011 | 05:09 PM
Beob's Avatar
69 442 Door Parts
Looking for window stops and clips for the upper door panels.
69 442 w/power windows
Thanks, Rob
Old Aug 24, 2011 | 10:31 AM
Beob's Avatar
Heres a pic of the only door panel clip I have, not even sure if all four are the same. If someone can let me know if all 4 are the same that would be appreciated to.
Thanks, Rob
Old Aug 25, 2011 | 04:30 AM
69442C's Avatar
Hi Rob,
I can't help with the parts but here are a couple of photos that show the upper door panel retainers you asked about. The front retainer is different than the one that goes at the back portion of the door. I'm pretty sure I have mine in the correct positions but I guess I'll find out when I install the door panels. Ignore my fancy window crank.
Brian
Old Aug 25, 2011 | 04:11 PM
Beob's Avatar
Thanks Brian.
Old Aug 25, 2011 | 04:35 PM
oldsguybry's Avatar
NOVICE car nut
Originally Posted by 69442C
Hi Rob,
Brian
I hope that vise grip is not too tight
Old Aug 26, 2011 | 06:16 AM
Beob's Avatar
Still looking for these 2 retainers and one window stop.
Old Aug 26, 2011 | 01:59 PM
2blu442's Avatar
Bob, I should have those. I'll see what I can find this weekend. John
Old Aug 26, 2011 | 06:53 PM
2blu442's Avatar
Rob, the first place I looked I found the door panel fasteners. Can you give me an idea what the window stop looks like? John
Old Aug 26, 2011 | 07:40 PM
Beob's Avatar
Awesome! I need 2 of the ones on the left in your pic. The other 2 I have located. I have a pair of stops in the mail, when I confirm they fit I will post a pic.
Thanks, Rob
Old Aug 30, 2011 | 06:04 PM
Beob's Avatar
John, Heres a pic of the window stop, I need the bigger one. Also need two of the same door panel retainers on the left in you pic. If you have two.
Thanks, Rob
Old Aug 30, 2011 | 09:55 PM
2blu442's Avatar
I've got the two door panel retainers. It may be the weekend before I have time to look for the stops, but thanks for posting the pictures. I'll use them to try and match it up for you. Are these at the bottom of the door, or somewhere near the top? John
Old Aug 31, 2011 | 04:22 AM
69442C's Avatar
John, the larger window stop that Rob needs will be found at the front of the door near the top/middle. If you look at the attached photo you will see a large opening on the right side of the photo at the top. Below that opening is a smaller one. The bolt for the larger window stop is in that smaller opening.
Brian
Old Aug 31, 2011 | 06:24 AM
507OLDS's Avatar
Looks like you got things handled,but if you come up short,I have boxes full of that stuff.I strip every door if it's junk.My parts are from 70-72 doors,but most or all of the pieces should be the same.
Old Aug 31, 2011 | 10:48 AM
Beob's Avatar
Thanks to all for your help! I have another pair of window stops in the mail, so I should have all 4 now. John , I will just need the 2 DP retainers. Sent a PM
Thanks, Rob
daveohiocutlassparts
Feb 23, 2017 01:35 PM
dfire25
Feb 3, 2013 07:38 AM
ddx77
Jun 24, 2010 10:49 PM
jmac69cutty's
Apr 13, 2009 07:42 AM
eke82
Ninety-Eight
Dec 14, 2006 05:40 PM
