68 Qjet
Old May 31, 2014 | 03:39 PM
Tom's Avatar
Tom
68 Qjet
I need a good core for a 68 Qjet for a 455. I have a 455 with a 67 400 intake so needs to be for the divorced choke set-up.
Old May 31, 2014 | 03:51 PM
dnmfranco's Avatar
Have a 8251 w divorced choke
Old May 31, 2014 | 07:24 PM
tru-blue 442's Avatar
Old School Olds
Tom, does your intake have the shallow pocket
for the choke coil or the deeper pocket?
There is a difference on the carb choke assembly
where the rod hooks up. Also the coils are different.
In this pic shows you what I mean.
The one on the left is 68-69, and the one on the right
is 66-67. Hope this helps.
Old Jun 1, 2014 | 09:48 AM
Tom's Avatar
Tom
I'm not real concerned with the choke. If I can't make it work with whats on there, I can always go back to the manual set-up that I had on there before. The carb on there now is a chevy carb and having some issues with it. Called Sparky to see if he had a Olds core to rebuild for it and he's out of those. Sparky said to go with a 68-69 carb from a 455. Still had the divorced choke and would work better on the 455.
I would be interested in the 67 carb since the 67 400 I have had a chevy carb on it also.
So email or pm me a price on the carbs.
Thanks for the help guy's.
Tom
Old Jun 2, 2014 | 07:53 AM
hookem horns's Avatar
If originality is not critical, get a 70+ core, convert to electric choke and block of the manifold port.
Old Jun 2, 2014 | 08:58 AM
There's nothing on the manifold to block. The pocket for the divorced choke is a blind pocket, not a hole into the crossover.
Just out of curiosity, if you have a 1967 intake and choke setup, why are you looking for a 1968 carb?
Old Jun 2, 2014 | 04:26 PM
Tom's Avatar
Tom
I'm going to send it to Sparky and have it rebuilt. I called him and he told me to go with the 68-69 from a 455. He said they will work best and then I can still stay with the divorced choke. Why stay with the divorced choke? No reason. Just like the way it looks.
Old Jun 5, 2014 | 01:58 PM
Old School Olds
Rochester carbs
Tom Here is what I found.
The one on the left is for a 67 400.
The one on the right is a 66 330?
I can't read the #'s on it. It has the
old style flush valve.
PM me for any details...
Old Jun 5, 2014 | 02:31 PM
Tom's Avatar
Tom
Those are Chevy carbs. I'm looking for the Olds carbs. Thanks for looking though.
Old Jun 5, 2014 | 02:38 PM
Old School Olds
No, these are Olds carbs.
The 67 # is 7027036.
Which in turn represents a 67 400
Olds big block.
The 66 came from an old 330
that was parted out years ago,
IIRC.
Old Jun 6, 2014 | 03:40 AM
ROCKETMAN269V's Avatar
The early Olds carbs had side inlet like chevy.
Old Jun 6, 2014 | 03:44 AM
Old School Olds
That is probably why he dismissed them.
The #'s also show the 67 carb for a 425
engine as well.
Old Jun 6, 2014 | 10:51 AM
Tom's Avatar
Tom
I apologize Adam. I thought they started the front load in 66. The carb on the 400 I got and the 455 in my 67 are chevy. The numbers confirm that. Guess I should check things out a little more before I open my mouth. Anyway, please let me know what you have to have for the 67 carb. Thanks.
Tom
Old Jun 6, 2014 | 12:20 PM
dnmfranco's Avatar
pm replied
Old Jun 6, 2014 | 03:33 PM
Old School Olds
No need for apologies Tom.
You don't know, you don't know.
This carb would probably work well for
you after a trip to the rebuilders.
Only problems with it that I know of are
the idle set screws. They are brass, but I
don't think they are long enough. The choke
pull-off won't hold a vacuum either.
Old Jun 7, 2014 | 05:00 AM
Old School Olds
PM sent Tom.
Old Jun 9, 2014 | 09:04 AM
Old School Olds
Tom, carb is on it's way, thanks.
agtw31
Apr 21, 2009 06:17 AM
captn442
Apr 5, 2009 06:28 PM
joe_padavano
Tech Editor's Desk
Mar 31, 2009 04:35 AM
geckonz08
Jun 7, 2008 01:26 AM
grimlock
Feb 20, 2007 03:44 PM
