68' 442 Headlight Surrounds
I hope you can find a decent pair. Mine were shot and I ended up buying a reproduction set from Fusick. The reproductions look great on the outside but the mounting them proved to be a bit of a challenge as a couple of the mounting "holes" on the backside of the surrounds weren't long enough to reach the core support. I had to add spacers to make it work right. But the repros are a option if you can't find originals.
Randy C.
Randy C.
Thanks Randy, will keep that point in mind. I can always cut some Delrin spacers on my lathe. These jewels are pretty expensive to buy new so I hope someone has a descent set at a reasonable price. I started taking one off just to repair a running light socket. A LOT of work just for that but I'm picky. Seeing the condition mine are in I need to replace them. Crazy that you have to drop the bumper to pull these to get to the parking light/turn signal.
have an nos one and other side is a good used one if interested
I bought mine 8 years ago, in 2007, from Fusick. They do look great but I had to shim up a couple of the fastener areas in the back so they would be flush with the core support. That would be great if the newer editions were better!
Randy C.
Randy C.
crazy'boutOlds
July 22nd, 2010 03:13 PM
