672 or 588 Type O posi
Old Nov 6, 2017 | 10:34 AM
rktolds's Avatar
I will be picking up some factory 3.91's. Looking for GM posi to go with these GM gears. Thanks.
Matt
Old Nov 6, 2017 | 02:44 PM
Depends upon if you have an O-Type with HD 31 spline axles or a standard 28 spline axle rear.
Info from Brian Trick:
Here is a list of the posi units & what gears they will fit:
#673 = 2.56 & 2.78 ratios, 28 spline
#671 = 3.08 & 3.23 ratios, 28 spline
#588 = 3.42 & anything numerically higher, 28 spline
#672 = 3.42 & anything numerically higher, 31 spline
Old Nov 6, 2017 | 07:11 PM
rktolds's Avatar
I may build it with aftermarket axles. So open to either posi. May have located one today. Thanks.
Old Nov 6, 2017 | 08:44 PM
My understanding is the housing for the 31 spline axles has larger diameter carrier bearings than the 28 spline housing, so if yours is an original 28 spline housing then I don't think you can fit a 672 carrier in the bearing saddles/caps.
Old Nov 7, 2017 | 06:50 AM
Rocket North's Avatar
588 Posi
PM sent.
Derek
Old Nov 7, 2017 | 04:36 PM
rktolds's Avatar
Posi found. Thanks guys.
Mar 17, 2017 09:35 AM
66trakpak
Jul 15, 2016 04:59 PM
rktolds
Jun 1, 2015 06:38 AM
Bob Kelso
Jul 24, 2013 12:32 PM
