67 Delmont 88 425 flywheel
Old Dec 6, 2017 | 08:19 PM
golden rocket's Avatar
golden rocket
having big time grief trying to find a flywheel or ring gear for my Olds. Has the 425 c.i. engine w/ turbo 400 behind it. appears to be stress cracks in flywheel, and takes multiple tries to find good place on flywheel to start. The 330, 400, 425, and maybe 455 should be about the same. Looking online, all the flywheels are for manual transmission.
Anybody have any ideas on where to get a flywheel, teeth on Bendix are good, as that is what I had originally suspected. rotated flywheel through starter engagement hole, lots of worn teeth.
thanks for any info/ help. mike
Old Dec 6, 2017 | 09:29 PM
Try searching for a flex plate instead of a flywheel. A flywheel is for a manual transmission whereas a flex plate is for an automatic transmission. Also, the 455 flex plate will not work with the 425 - you need one for a 330, 425, or early 400 engine, all of which are 1967 or older. The 1968 and newer flex plates have a different bolt pattern and will not work.
Old Dec 7, 2017 | 06:55 AM
Any 1964-1967 Olds flexplate works - they are all the same. The 64-67 motors cover the 330, B-block and E-block (short stroke) 400, and the 425. A 455 flexplate will NOT bolt up, nor will any 1968-1990 flexplate. You can buy a brand new SFI flexplate from Jegs or Summit for about $130. Speedmaster P/N 1-226-004 has both early and late bolt patterns and a balance weight that can be moved to the position appropriate for each application.
Old Dec 7, 2017 | 07:10 AM
tru-blue 442's Avatar
Old School Olds
Flywheel.
I have this one if you want. No cracks and the teeth are in great shape.
Old Dec 8, 2017 | 03:04 PM
RAG's Avatar
RAG
I have one in Albuquerque if you are still looking, $75 includes shipping.
Old Jan 10, 2018 | 09:36 PM
golden rocket
Haven't been on for awhile, between the heart and the lung trouble, and the cold weather, been on the downside. Had to farm out the flexplate job, not able to crawl under as good as I did 50 years ago. 7 decades come September.
Mechanic says when he enters Holiday Coupe in he gets different part number. I'm stating to scratch my head in wonder (if he knows what he is doing). Will go to Summit website and get things moving on it, I want my baby home.
Old Jan 10, 2018 | 11:03 PM
i doubt Summit will have an early (pre-1968) flex plate. Most likely they will have only the later ones that don't fit your engine.
Old Jan 11, 2018 | 07:29 AM
Care to put money on that?
https://www.summitracing.com/parts/a...ake/oldsmobile
I think you already know the answer to that...
Old Jan 11, 2018 | 07:31 AM
I'll try to anticipate the next question.
Yes, all STOCK Olds motors use EXTERNAL balance.
Old Jan 11, 2018 | 09:17 AM
lemoldsnut's Avatar
I can do the correct flexplate.
Larry
lemoldsnut@aol.com
541-815-4363
Old Jan 11, 2018 | 03:39 PM
Well that sure surprised me.
Old Jan 12, 2018 | 08:23 PM
golden rocket
Summit does have the flexplate, but JEGS is cheaper on the price. Hays is a steel one for $109.95, Hughes @ $ 152.99, and ATI for $227.99. all are free shipping since purchase is over $99.00.Anybody care to weigh in on which one is best?
And Joe is correct (once again) all are 166 tooth with External balance.
Old Jan 13, 2018 | 08:43 AM
They are all steel. The SFI certification is only necessary if you plan to drag race. There are Chinesium non-SFI rated versions available in the $60 range, but I would not recommend those. Frankly, I'd just get a used original and not look back.
Old Sep 13, 2018 | 07:52 PM
rogue_ryder's Avatar
G-Body Driver
Speedmaster flywheel. I just got this in direct from speedmaster. It was cheap but you can see why. This is a 330 crank
Old Sep 14, 2018 | 05:11 AM
ROCKETMAN269V's Avatar
Did you try using the other bolt pattern?
Old Sep 14, 2018 | 08:23 AM
G-Body Driver
I swear I rotated this thing around 1080* and this was the closest pattern! (I marked one hole to make sure I didn't miss any as I rotated it). I will look again this evening, but I'm 99.9% certain, that this is the closest pattern. There's a used oe flexplate on eBay but they want $120 for it. (ouch!). I was hoping that I'd get this crank back to the machine shop today so that they can balance it.
Old Sep 14, 2018 | 09:16 AM
Not to sound stupid, but are you sure that it's facing in the correct direction? I can't understand why they would put a dual pattern on it, unless it fits some other make of engine. BTW, I have a couple of good used ones, if you like. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Sep 14, 2018 | 05:53 PM
G-Body Driver
I definitely did a stupid! It was facing the wrong way! That’ll teach me for trying to work on stuff late at night. I swapped it around so the weight is on the front side and all is well.
FWIW I paid $37 plus shipping directly from Procomp on eBay. The dual pattern is supposed to fit all Oldsmobile cranks from 64-90.
Old Sep 15, 2018 | 05:28 AM
Glad that it worked out.
Boldsmobile
Dec 28, 2018 01:36 PM
oldcutlass
Jul 31, 2017 06:19 AM
bluecab
Aug 6, 2015 08:38 AM
cutlassefi
Apr 28, 2014 05:15 AM
64Rocket
Jun 12, 2009 01:10 AM
