67 425 4 barrel intake
Old Jan 21, 2011 | 08:15 AM
made in the usa's Avatar
hello all I'm looking for a few odds and ends. would like a factory 4 barrel intake with matching carb. and need the air cleaner. a dash clock that works for my 67 delta 88 any help and prices be great i had got some prices from some folks but cleared my message thing and didn't remember who they were from now. had some down time from work so car has been on back burner for a while.
Old Jan 22, 2011 | 06:13 AM
my83432's Avatar
I have a intake carb and air cleaner from a 1965 olds 98 with a 425. Would this work for you?
Old Jan 22, 2011 | 06:19 AM
2blu442's Avatar
It may help if you posted your location. The intake will be a heavy package to ship very far. John
Old Jan 22, 2011 | 07:16 PM
hello all forgot about that I'm located in ansonia Ohio 45303 does anyone out there think the 65 intake and air cleaner look the same. carb linkage may be different i don't know any info be help full. what is your asking price and do you know how bad of shape the carb is in. any pics be great
Old Jan 22, 2011 | 07:23 PM
2blu442's Avatar
Depends on your goals. The 1965 intake will bolt up just fine, but 1965 used a 4 jet carb and the 1967 used a quadrajet. I think you could make it function but it will look very different from the factory 1967 setup. John
Old Jan 22, 2011 | 07:30 PM
I'm still shooting for OE look so i should try to find 67 only then thanks. if i was going to just run a 4 barrel it be a new aluminum intake and a street demon carb. but maybe i should run that way. I'm going to keep my original parts to be put back on if need be. any other ideas or year range are help full thanks again.
Old Jan 22, 2011 | 07:44 PM
2blu442's Avatar
I think you could use from 1966 to 68 and have the same appearance. The main difference is each year has a slightly different divoiced choke. The intakes have a different depth for the spring. But at a glance I think they would all look the same. Then for the carbs you would need to get one for your application. I have a 1967 330 in a Cutlass and a 425 from a Toro both with 4 bbl carbs. The throttle attachment is different. You might be able to make it work, but it would be different. John
Beau Dirt
Dec 27, 2021 03:02 PM
RetroRanger
Nov 21, 2016 10:11 AM
63 F85 Cutlass
Feb 8, 2015 03:20 PM
66ninetyeightls
Mar 28, 2010 07:40 AM
