66 Cutlass Gas Tank
Old Oct 14, 2017 | 08:01 AM
RonFX's Avatar
66 Cutlass Gas Tank
Guys:
I need a nice condition, clean gas tank for my 66 Cutlass. If it does not have the sending unit, that is OK. Shipping to Grove City, Ohio 43123
Thanks, Ron
Old Oct 14, 2017 | 08:23 AM
lemoldsnut's Avatar
I might have one. They are not too expensive new you know
Old Oct 14, 2017 | 09:01 AM
RonFX's Avatar
All of the replacements have 2 vents at the rear of he tank, mine only has one on the R/S near the front of the tank. I would rather get a OEM tank from a member if it is in nice condition.
Thanks, Ron
Old Oct 14, 2017 | 10:42 AM
66-3X2 442's Avatar
Thanks, Ron
All you have to do is buy a 66 Chevelle SPECTRUM/QUANTA tank from Rock Auto as they have the best price. Then remove the Chevelle filler neck and put your 66 Olds filler neck in the Chevelle tank and it will be totally correct tank.
Old Oct 15, 2017 | 01:59 PM
lemoldsnut's Avatar
PM sent I have a nice 66 tank
Larry
lemoldsnut@aol.com
Old Oct 15, 2017 | 04:25 PM
65B01Delta's Avatar
I have a very nice one out of a 67 Cutlass (California Car) located in Southeastern, Indiana, 30 miles west of Cincinnati, Oh.. not too far from you.. zip 47025. Lawrenceburg, Indiana
Old Oct 15, 2017 | 06:20 PM
66 POST's Avatar
Smile
Thanks Mike --- Good to know
Old Oct 15, 2017 | 07:12 PM
66-3X2 442's Avatar
Glad to help. Absolutely no reason to use a used tank when a top of the line repo tank will work and be exact. I think the tank in my car cost me $90 from Rock Auto and another $35 to have the Olds neck put in. If you look @ the 64-66 GM A-Body tank listings,they all are the 37 series GM tanks and all have the correct vent system and capacity. They are identical but the wagons use a different tank. I tried and tried to get Spectrum/Quanta to make the correct 66 tank by putting the 66/67 Olds filler neck in the 64-66 GM A-Body Chevelle tank to no avail. I worked with them for over 2 years trying to convince them all they had to do was put the Olds neck in a Chevelle tank to make it correct. I even sent them pictures,GM part #'s showing the 66/67 Olds tanks being different but they wouldn't listen. I think they put a tank out with part # 37F for a 66 Olds but it's without a filler neck and charged a lot more than you can buy a Chevelle tank for and the tanks are identical in every respect. I'm tired of typing.
Old Mar 9, 2021 | 12:18 AM
66SportCoupe's Avatar
If it's a 66 put an advertised 65 tank in. 67 has a totally different vent system.
Old Mar 9, 2021 | 06:41 AM
66-3X2 442's Avatar
The 65 filler neck is different than a 66. It doesn't have the curve to make it fit the rear frame x member. You can put a 65 tank in and you can get fuel in but it's harder.
jensenracing77
Aug 28, 2017 04:47 AM
matchek
Apr 1, 2015 06:37 AM
Jocko124
Jun 4, 2011 12:34 AM
cegulley
Oct 1, 2010 03:37 PM
RAMBOW
Jun 26, 2009 08:38 AM
