66 67 442 Choke Coil/Housing
I am not sure , maybe the difference in the rod arm is in the application: toro, A body, or big car; as the coils and rods i have came from numerous cars including both 66 cutlass , 442, toro, and big car. same for the 67 units i have. I have a stock 66 442 with the OEM carb and choke so I can match that application up.
If you could e mail pictures and a price for the 66 442 choke w/rod that would be great, thanks
drees@oh.rr.com
drees@oh.rr.com
I don't think trans made a difference in the choke coil.
Been a while since I looked those up in the PN manual though.
Pretty sure it goes:
66-67 exc. Toro
66-67 Toro
1968-9 [all?] 4-bbl
Then by 1970 we had the big round black coil on the carb. Like 2-bbls have had for years.
66-67 exc. Toro
66-67 Toro
1968-9 [all?] 4-bbl
this is what I pulled from an ebay auction, so maybe trans ( jetaway ) vs 4 speed or th400 and a/c does matter? this info below was for the 29984 B-1 unit. I have many 29984 B-1 units some with toro rods so think this was an a/c unit.
I also know that unit 33762 is from a 67. what I need to know is what is the correct unit for 400 442 with auto jetaway and A/C if the info below is correct than what part does not exclude jetaway with a/c ?
- 1966 V8 330 c.i. all transmissions (excludes Jetaway with A/C) Rochester Quadrajet 4bbl Carburetor
- 1966 V8 400 c.i. A/T (excludes Jetaway with A/C) Rochester Quadrajet 4bbl Carburetor
- 1966 V8 400 c.i. all transmissions (excludes F-85, A/C, & 4-4-2 with Jetaway) Rochester Quadrajet 4bbl Carburetor
- 1966 V8 425 c.i. A/T (excludes Jetaway with A/C) Rochester Quadrajet 4bbl Carburetor (NOTE: will not fit 425 c.i. with low manifold)
- 1966 V8 425 c.i. A/T (excludes F-85, A/C, & 4-4-2 with Jetaway & A/C) Rochester Quadrajet 4bbl Carburetor (NOTE: will not fit 425 c.i. with low manifold)
BeenThere
January 21st, 2016 02:59 AM
BeenThere
January 9th, 2016 08:52 AM
