66 442 Steel wheels
Old Feb 15, 2017 | 07:51 PM
68442's Avatar
66 442 Steel wheels
Need a set of 14 x 6 steel wheels from a 66 442.
must be from a 66 due to the codes maybe 67 may be the same.
Old Feb 16, 2017 | 06:20 AM
Run to Rund's Avatar
I have one but not a set.
Old Feb 16, 2017 | 07:54 AM
68442's Avatar
What are the numbers/letters left/right of the valve stem?
Need to have "6", and maybe an "A", "A3", "A4"
The letter codes are not on every wheel but the "6" is
Old Feb 16, 2017 | 09:53 AM
lemoldsnut's Avatar
I might have a set we have some bad weather need a little nicer day to go check. email me direct and i will check as soon as I can and get back to you
Larry
lemoldsnut@aol.com
Old Feb 16, 2017 | 10:58 AM
66-3X2 442's Avatar
65-68 442's & Vista Cruisers used the 6" R code wheels. There were some R2 wheels used also with the 2 being between the legs of the R. I have seen some A code 6" wheels also but the PIM/assembly manual shows the R codes being correct.
Old Feb 16, 2017 | 12:13 PM
lunaboy's Avatar
The Rocket Astronomer
i have seen two different R code 14/6. The R 2 has quarter inch drill holes around the Hub and you can find them on 66 jet star 88 cars. The A wheels 14/6 came off a 64 442, I believe 65 has them as well.
Old Feb 16, 2017 | 02:44 PM
68442's Avatar
I know about the R code wheels.
I need them for a 66 chevelle SS and was told 66 GTO'S. 442'S and GS'S could have had them as well( The "#6" code wheels)
Was hoping to get lucky with some one with 66 parts may have some here
Old Feb 16, 2017 | 06:17 PM
geowindow6768's Avatar
I have a set of wheels off my 67 Vista Cruiser. Unfortunately they are at the back of the shed so I can't check the numbers until spring
Old Feb 16, 2017 | 07:10 PM
Paladin31's Avatar
Wheeled
I have this in the stash, Kelsey Hayes March 67 RB coded though, if anyone can shed some light on the application as well be much appreciated
Brett
GoodOldsGuy
Apr 22, 2013 12:36 PM
69442murph
Feb 19, 2012 05:00 AM
Wraythe
Feb 10, 2012 08:19 AM
WTony
Jan 15, 2011 07:53 PM
oldzy
Jan 29, 2010 06:06 PM
