66 442 Jetaway
Old Aug 14, 2016 | 06:34 PM
edzolz's Avatar
66 442 Jetaway
I would like to find the valve body from any 66 400 engine with the Jetaway. The 66 service manual shows a different part number from the 330 trans. It also says there are more clutch plates in the 400 engines transmission. The clutch drum might be different too.
Old Aug 16, 2016 | 06:03 AM
edzolz's Avatar
surely someone has changed out the ST300 (Jetaway)for a later three speed in their 66 442.
Old Aug 16, 2016 | 07:17 AM
TripDeuces's Avatar
"surely someone has changed out the ST300 (Jetaway)for a later three speed in their 66 442"
Many have done this but that wasn't the question was it or did I miss something?
I swapped in a TH400 in place of my Jetaway but in a 66 that involves an aftermarket cross member as the TH400 was not an option in an A-body of that year. Many have also used TH350, 700R4, 200R4 etc.
Your thread was answered in another forum also. Seems no one makes a shift kit for the ST300 and the only mod I saw was on a Buick forum that involved opening up the primary feed hole from .090 to .125 for a firmer 1-2 shift. It also modified the governor weights and spring for a higher shift rpm.
I suspect these are the exact mods in the valve body and governor that GM did between the 400 and the 330. Unfortunately that doesn't address the deficiencies in the ST300 overall. Swapping it out is probably the best advice and idea.
Old Aug 16, 2016 | 09:56 AM
edzolz's Avatar
Mainly what my comment was meant to be "does anybody have a 66 442 Jetaway they want to get rid of." It should have an NJ code on the servo cover. I'm not replacing anything. I'm using this trans in a street rod.
Old Aug 16, 2016 | 10:21 AM
Okay, I realize this isn't particularly helpful, but I have to know: why would you want a Jetaway in your streetrod?
Old Aug 16, 2016 | 05:15 PM
lunaboy's Avatar
The Rocket Astronomer
the code NJ for 65 442 would have the same recalibrated valve body for a more positive (harder) shift as the 66 442 Jetaway.
Old Aug 16, 2016 | 08:40 PM
edzolz's Avatar
Purely economic. I have three of them. Not a hot rod car, just a cruiser.
Old Aug 16, 2016 | 08:56 PM
lemoldsnut's Avatar
I probably have two or three as well
Larry
lemoldsnut@aol.com
HonestDave
Nov 16, 2014 05:00 PM
442Dave
Sep 17, 2011 07:35 PM
Flye
Mar 1, 2011 05:50 PM
clloyd
May 12, 2006 07:28 AM
<Derek Anthony>
Nov 26, 2005 05:14 PM
