65 Cutlass power steering pump with reservoir
Mines leaking bad on my 65 cutlass and want a good one to install and use till I find time to rebuild my old one. Non A/C car. Motor is 65 400, but believe pumps/reservoir are the same for 330 and 400? Thanks
Thanks, I've never rebuilt one before...so figured it would be a challenge. Being risk adverse, if I had a good one to swap out and I messed up the rebuild it wouldn't set me back too far. Does anyone know the correct PN for the rebuild kit? Thanks
Are you sure it is the pump leaking and not one of the hoses? The return hose have been known to leak because of age and with no pressure it is not easy to locate a leak from the hose. A high pressure leak will spew fluid when turning the steering wheel.
Hoses are good, leaking out the front somewhere and running down the large mounting plate and onto the ground. I placed a sheet of paper underneath the pump. It's leaking bad statically...not pressurized and the same when running. Level drops 2" a day. A good paper plate size puddle after a couple days.
