64 F-85 heater box
Trouble is I have parted 64's and 67's so if they are the same I wont know.... I also would not know which is which at this point....
How bad is yours? Found one here but has a couple of pin holes. Overall pretty solid holes are where it was laying. Couple of zaps with the welder and you should be ok...Maybe you can find a nicer one from those AZ junkyards?
Not sure if you're just looking for the heater core. I was looking for one for my 66 Dynamic a while ago.
Classic Heaters was the place where I found they had one. If they don't have one of your type in stock, I'm sure they could see if your old one is repairable and fix it if you're lucky. That is, if you have an old one.
http://classicheaters.com/
If you don't have access to a welder to patch the one from Oldsmaniac I've got one I believe came from a 1965. I'd still say mine needs to be media blasted and repainted to look nice. If you don't need the fan motor I can pull and keep that. I'm attaching a couple photos, but there are several more with closeups on my photobucket site at:
http://s90.photobucket.com/albums/k257/2blu442/
jeffs 89 cutlass salon
October 22nd, 2007 12:46 PM
