62 olds dynamic 88 need heater actuator diaphragm
Old Jul 22, 2017 | 12:59 PM
jenniferboyce's Avatar
Unhappy 62 olds dynamic 88 need heater actuator diaphragm
Non air conditioning car. Need AC part # 3144212, heater actuator diaphragm. It is located on fire wall duct work and runs off engine vaccum. Thanks, Mike @678-429-2273
Old Jul 22, 2017 | 10:00 PM
1962olds's Avatar
Try http://www.oldairproducts.com/catalog. I got one from them years ago.
Old Jul 23, 2017 | 08:20 AM
Thanks, I will contact them. Mike
Old Jul 24, 2017 | 07:32 AM
dennis_30281's Avatar
Diaphram
I have removed the heater from my 62 Starfire convertible and replaced it with a Genair II. I would have to test the diaphram first but I have the whole setup. Email me if you need it.
Dennis
Old Jul 29, 2017 | 08:55 AM
Duneracer's Avatar
Rebuilt vacuum actuator
I also have 62 Dynamic 88 and I was looking for vacuum actuator with no luck I looked for four months I also tried the two vintage air companies with no luck and I did not won't to spend 300 for two actuator on line . So I made fixtures to take apart what I had and a friend had two vacuum actuators that would not work but were good. I took them apart took the diaphragms that were good cut the arm to match what I have and resized the actuator. I put the actuator in my dies and used a press to seal up . It worked no leakers everything works on my heater I also rebuilt the push buttons and vacuum selectors . May be I can help if you can't find any
Old Aug 1, 2017 | 05:41 AM
Thanks for the help. Mike
4Ceesuns
Jun 6, 2014 02:54 AM
oldspackrat
Dec 8, 2013 08:06 PM
MN71W30
Mar 9, 2013 02:37 PM
wmlewis
Mar 15, 2012 10:21 PM
Steve Wike
Oct 26, 2010 06:35 AM
