55 olds 88 roof brace needed
Old Jan 15, 2011 | 07:08 AM
jozw30's Avatar
Anyone parting a 54-56 olds 88 that has a solid roof area? I pulled the headliner down on my 55 88 sedan project and the mice had nested up in the metal clamshell that runs across between the A-pillars. The mirror and sunvisors mount to it.
It's all rotted.
The roof skin and window channels are perfect.
Don't know for sure if this part is the same for sedan, Holiday or 4-door?
Thanks!
Joe
Old Jan 17, 2011 | 08:18 AM
Olds Dad's Avatar
Collector of Stray 55's
I am going to see a parts car next week ... if i get it i will get you this piece...did you figure out how the pillar interior panels ( between the doors ) come off...are they just tacked?...replacing windlace and headlineron a sedan as well...tks
Gordon
Old Jan 17, 2011 | 06:15 PM
jozw30's Avatar
Gordon,
Thanks for the reply. I did some interchange research and it looks like the part I need will have come from a 2dr or 4dr sedan.
I have no experience with the 4dr so I'm not sure about how the "B" pillar is welded. I'm in for some work replacing this front section based on what I see.
My hope is to just have someone cut the front 8 inches of the roof off with about an inch of the "A" pillars. This way I can figure it out in my garage .
Is the parts car you are going after a sedan?
Thanks again!
Joe
Old Jan 17, 2011 | 08:57 PM
56oldsnub's Avatar
Joe,
I know exactly how you feel. The same thing damage was done by mice on my 56 Ninety Eight Holiday I'm working on. Must be a favorite nesting spot or something. (see photo)
Can I ask where you did your interchange research. I have the 56 Holiday 98 and I have a 56 98 4dr sedan. I would like to find out if some of the parts can be interchanged.
Bret
Old Jan 18, 2011 | 04:39 PM
jozw30's Avatar
Bret,
Damage looks familiar. Mine's not quite as bad along the side rail areas. The worst on mine is towards the middle.
I picked up a PDF based interchange manual CD on Evilbay pretty cheap.
If you just need a couple things looked up, let me know.
From what I've seen with the 88's the sedans kinda go together body part wise. And the Holidays interchange.
Joe
Old Jan 18, 2011 | 05:23 PM
jozw30's Avatar
Bret,
For your roof, the manual says you have to stick with the 2 dr H.T. for interchange, but you can also get parts from a 54-56 Buick Special and Century 2dr H.T.
Hope that helps.
Old Jan 19, 2011 | 11:21 AM
56oldsnub's Avatar
Thanks Joe...I'll have to look into getting an interchange manual
80_Olds_Guy
Aug 1, 2013 08:00 AM
droptopron
Apr 6, 2013 03:02 AM
bigin1978
Feb 18, 2012 06:45 PM
Blake Willoughby
Feb 5, 2012 09:29 AM
