54 olds 324 dual action fuel pump
Be sure and check which pump you have. I think they used two different type pumps in 54. One had a straight arm and the other had a slight bend in it. I don't remember which is the early model and which is the late. If you have the later model, the 56 pump should fit. Try Fisicks for the pump. They show up on ebay pretty often but on a fuel pump that old you are taking your chances.
joe_padavano
February 10th, 2009 05:41 PM
