425 v8 in NY?
425 v8 in NY?
I am looking for a good running 425 v8.I will need a trans as well but I am after the motor for now.I found one but it may not be worth buying.Anyone in New york state have one to sell.I would prefer a 425 but might consider looking at a 330,olds 350 or maby a 455. but I have a 455 for another project.Let me know what you have and price.
The one I am looking at he wants $500 and says it ran when parked.But he has several parts off it so with out a harmonic balancer and flywheel it can't be started.But he wants $500 and he said he would sell me the trans for $200.
Walk away.
You can get a running motor for $2-300 if you're patient.
How long it will run, well, that's another story, but even that beats "can't be started."
Also, for whatever it's worth, I spent some time working in a junkyard as a kid.
The boss used to say "Go get a slant six off the rack, pull the plugs and turn it over a few times to get the water out - a guy's coming over in half an hour to buy it."
'Nuff said.
That's too much.
Walk away.
'Nuff said.
Walk away.
'Nuff said.
http://nh.craigslist.org/pts/2946170858.html
says olds 425 drivetrain...not sure what it includes GL
Sounds good but are you in NY or out of state.I could not complain for that price but if your out of state I would have to figure out shipping.
hmm said that when i posted the link,,,maybe that promoted a sale
I was origionally looking for a 425 engine in new york state as it would be easier to get and shipping would not be involved.But it seems they are far few and between.I have in the past found more 455's than any other engine.I had this in the listing:I would prefer a 425 but might consider looking at a 330,olds 350 or maby a 455. but I have a 455 for another project.I also said about a trans since the car the engine would be going in has no trans.I did get one above offer and as you can see I messaged back and got no response only now did I notice the phone number duhh on me.So with all that said if any one has a good running olds engine for a decent price and it wont be crazy for shipping let me know.I did want to go 425 but I want to find some offers.The car is just a rollling chassie project at this point and I can't go much farther without a drivetrane and I do not want to put a sbc in a olds.Thanks and hope to hear from someone
425 but not olds?
I have been looking for a 425 olds engine or the others listed and have not found one.But I came across this 1977 425 ci cadillac motor and 400 trans.Now it is not olds but now I wonder what is different between a cadi 425 and a olds 425.DO they bolt different or are parts not the same as olds.I am considering this as a option as it is a good price and it runs.So it is a better deal than the last 425 I was looking at and it comes with a 400 trans.So with all that said opinions please and any info on what would be different.Would it just drop in to a olds that was a 425 or would some mods maby be needed to fit a cadi 425.
425 From Michigan
I might have checked this ad out more, if I hadn't first found a 455. This ad is from Cruis'news, June 2012, page 68... www.cruisnews.com search the site... (Rebuilt Olds 425 motor complete)
512-004 - Rebuilt Olds 425 motor complete (2bbl, Carb, exhaust manifolds, alt., P.S. pump) trans and driveshaft.
$500 obo.
More info 248-624-8073
B.T.W. I have two non-running 425's that need to be rebuilt.
F.Y.I. Jaybird
Timing is everything!
$500 obo.
F.Y.I. Jaybird
The 425 has the same external dimensions and attachments as the 472 and the 500.
As for whether you had enough clearance for all of the front-of-engine components, you probably would, since the '77 Caddys were pretty much A-body sized, but you never know.
And don't forget that that motor was only rated at 180hp.
Opinion: Hell no.
No, it would not.
Maybe.
$500 obo.
F.Y.I. Jaybird
$500 obo.
F.Y.I. Jaybird
Everything.
The transmission bolt pattern should be the same, but the motor mounts will be in different places. I do not know where and how Cadillac motor mounts bolted up, but I doubt you'd luck out and find that they bolted into the same points in the Olds frame, since Caddy frames are different.
Opinion: Hell no.
No, it would not.
Maybe.
Opinion: Hell no.
No, it would not.
Maybe.
I have been unable to find a local 425 worth getting.I have seen ones that were out of state but shipping would be ruff.But I recently found a 350 olds with th350 trans that is a option.What I need to know is what mounts will be needed since it is going were a 425 was and the orig trans was th400 and if I remember correctly the trans mount is off a bit from a th400 to a th350.I can get this for a good price just need to know what will be off and what mounts will be needed to put er in.
Go For It!
Hey delmontcruiser: Go big or stay home! There are many 455 engines available. Try looking for a good rotating assembly.
My new 455 is currently being rebuilt. My man Dave said he hopes this thing is out of his yard by the weekend!
Yes!!
Yes!!
well I was after a 425 and though a 455 has power and is a good engine.I have one waiting to be put in my 4dr.I found this one for $300 with trans all I would have to do is add a power steering pump and mounts.The car the engine is going in does not need to be a total power house since it is going to be a ratrod fun car.Not that I don't like 455's just would have prefered the 425.
You should be able to use the same engine mounts, as the bottom of the blocks are the same between big and small blocks. The exhaust will be a problem, especially if you have single exhaust; the crossover for a big block is longer. The bigger problem may be the transmission. First of all, you'll need to come up with a kick down cable set-up. The T-350 didn't come out until 1969, so there is no provision on your gas pedal, or firewall for one. Also, you'll need a longer driveshaft, with a different yoke. There may be other issues, but these are what come to mind right off. Bob.
I live near Rochester about 10 miles or so to the west of the city.Now here is the funny part i bought the car that I need the engine for not all that far from albany.I got it in vorheesville about two years ago.
If a decision is made any time soon as to actually being for sale, I will let you know ASAP...... I can tell you, the 425 engine and the 400 trans were removed from a 67 98 convertible..... Both were supposedly rebuilt only a short time before the car was damaged from being in a house fire, and the damage to the car was only heat and water damage and not actual fire (burned) damage.......
Good Morning, I have a complete Oldsmobile 350 2BBL with 2 Speed Transmission in a 68 Cutlass that is driven freqeuently. About 100K on motor, new water pump, slight intermittent blue smoke, transmission I was told has been rebuilt and shifts very smoothly. I will be removing the engine/transmission in the upcoming months to put in a 455 and will not be needing either. I am located in Central NJ. Price is $500.00 for combination. Let me know if this helps, Vin
I have been mia for awile but still looking
I had a few potentials but still looking for that 425 or 455 v8 and th400. The project is getting closer to getting it's shop time but will be limited if I don't find the drivetrain. I now have a truck that can haul the motor and trans with as well.
This thing's been on Craigslist for along time. If it's running, pull the motor and part the rest or scrap it. I'll bet you can get it for $600.
http://fingerlakes.craigslist.org/cto/4663682096.html
The 425 I mentioned in my previous post (Can't believe it's been over 2 years) is now in my garage and for sale.... I will also include the 400 trans if you still need it.... I cleared the area around the engine recently and rotated the engine a couple times too make sure it was not seized.... Like I said previously, it was supposedly rebuilt shortly before the fire... It is complete carb to pan and I am asking $600....
#31
Wow nice you still have it I figured it would have been long gone. I am interested and do still need the trans.
#32
steve walker
December 17th, 2019 12:32 PM
