330 flywheel
330 - 425-....'64-67 manual tranz FLYWHEEL
Old style
67 or earier 330&400&425 ...same bolt pattern
Servicable implies most all its teeth & surface a disc could employe with friction & aid Tranz & Diff in smokin rear tires off it...
Not to be confused when flex plate which bolts to the rear of the crankshaft and the front of the torque converter
On AUTOMATICS
for some reason I seem to have a few of those OF either category as well as the latter 68 and up of either category anyone wishing to purchase those IS ADVISED get ahold of me at my email address anybody not wishing to should not use my email & try whatever other way doesnt realy work..
Omishjon4@gmail.com
Thank
If you no longer find yourself in need , could you inform me if your starter has the IRON , manual tranz nose ?
On AUTOMATICS
Omishjon4@gmail.com
Thank
djsoldzparrts
November 11th, 2008 06:46 AM
