307 olds alternator non A/C brackets and bolts needed.
Old March 13th, 2022 | 08:06 AM
monzaz's Avatar
AS stated need NON A/C passenger side alternator brackets
GM USED is fine
Also the knowledge of which groove or pictures of the set-up
Have the A/c set-up but car will be hit hard off the line a lot so we would like to balance out the tension of the belts not all on one side.
Thank Jim
Akron Oh
Old March 13th, 2022 | 10:46 AM
oldolds88's Avatar
you have pm
Old March 13th, 2022 | 12:44 PM
Jim, FYI, the 307s never used a passenger side alternator bracket, so pulley alignment will be hit or miss. Even non-A/C cars mounted the alternator on the driver's side because the A.I.R. pump was on the passenger side. Your best bet is to find a complete set of pulleys from an earlier Olds motor with the same water pump length.
Old March 15th, 2022 | 08:17 AM
monzaz's Avatar
does anyone have a single power steering pulley ...this guy gave us a dual groove pulley on the pump so the alt belt can not pass the PS pulley.
then the next problem we have is the alternator adjuster bracket at the bottom of the alternator needed .
I do not do Oldsmobile motors so this is all foreign to me... we are trying to help out a long time friend that has had MS his whole life and this is his last chance to get a car on the road...He is a deep Olds guy and wants this 455 in the 86 cutlass...lol.
Jim
Old March 15th, 2022 | 08:39 AM
Jim
If the owner doesn't care about the A/C, then throw away all the 307 brackets and just use 68-72 Olds brackets, water pump, and pulleys as a matched set. The alternative will be constant trial-and-error mixing and matching.
Old March 15th, 2022 | 01:00 PM
monzaz's Avatar
so we were hoping the belt would ride on the A/c inner most pulley of the pump and crank
Old March 15th, 2022 | 03:00 PM
jcdynamic88's Avatar
i very likely have
the brackets and pulleys you want if you still need.i dont really want to dig through boxes only to have you say you got them.i know i have right side alternator brackets,2 groove wp pulley and crank pulley.either 65 or 66 parts
Zennex
July 29th, 2021 11:43 AM
clessard
February 16th, 2016 06:13 PM
lemoldsnut
September 18th, 2014 11:12 AM
QS442
November 23rd, 2013 08:45 PM
37OldsCoupe
April 8th, 2010 12:31 PM
