1975 Cutlass Salon turn signal lever and dimmer switch control cover
Old Apr 6, 2018 | 06:45 PM
jhoppeolds's Avatar
Need plastic turn signal lever and dimmer control cover and boot. Steering column mounted. Different than '78 and newer versions. Held on by small 1/4" headed screw on backside.
Old Apr 6, 2018 | 08:05 PM
toymobile's Avatar
I have a 77 parts column , will check in the am.
Johnny
Old Apr 7, 2018 | 05:24 AM
toymobile's Avatar
Not the same, wish I could help.
Good luck
Johnny
Old Apr 7, 2018 | 05:42 AM
oldsmbl's Avatar
I believe this is only found on a Cutlass Salon from 1975 - 1977. Greg.
Old Aug 8, 2019 | 07:07 AM
rstrick's Avatar
I have the same issue with a '77 Salon, the covering/boot for the column mounter dimmer switch has sun rotted away, the switch works fine just looks horrid.
Any ideas for replacement of cover/boot - I search steering column web sites and can't come up with the correct cover/boot -
is replacing the entire steering column with a newer one (floor shift, tilt, w/dimmer) an option and any ideas for what will fit
Thanks in advance for any and all help
Old Aug 13, 2019 | 06:20 PM
Bill G's Avatar
Hard to come by...cover is different for tilt...non tilt...
Nos is prob only option...and not many guys have 73 77..
Old Aug 14, 2019 | 09:00 AM
rstrick's Avatar
Does anyone know if other GM models had this turn signal/dimmer switch cover and if a later model Olds column might work as a replacement - floor shift, tilt and dimmer switch
bry593
Mar 16, 2019 08:27 AM
1956olds88post
Oct 10, 2013 03:50 PM
Rex
May 13, 2011 08:58 AM
oldroyale
Jun 6, 2009 03:18 AM
crazy'boutOlds
Oct 4, 2008 09:31 AM
