1974 Oldsmobile CS
Old Nov 29, 2016 | 12:16 PM
sammieolds's Avatar
1974 Oldsmobile CS
Hi everyone I think I need a new door lock mech I've tried to adjust the pin on the body side I can't get it to close tight unless I slam it I adjusted this 100 time I don't get it this is the drivers side door the pass door close nice the door is not sagging either any ideas thanks
Steve
Old Nov 29, 2016 | 12:51 PM
crimsoncolby's Avatar
Should be able to tell whether the door latch is operating correctly. Open the door and manually move the jaws that catch the striker. If they move freely, you're good. If not, try lubricating them and work them back and forth. I'd bet it's still an alignment problem with a slightly sagging door vs the striker. Does the door close easier when you lift up on it as you're closing it? Any signs of unusual wear pattern on the striker? I often see flat spots on the head of the striker from the latch not hitting it in the correct spot.
Old Nov 29, 2016 | 01:38 PM
sammieolds's Avatar
No the door is solid no play the mech moves in and out
I guess I'll have a body
Guy look at it it shouldn't be this difficult
Steve
Old Nov 29, 2016 | 05:56 PM
Hurstolds1973's Avatar
My 73HO
Did you try to take the latch pin out and close the door to see if its maybe a worn or sagging hinge or pin? See if it lines up correctly..Sometimes the little plastic ring on the latch pin is work or missing also..
Let us know.
Old Nov 30, 2016 | 04:28 PM
sammieolds's Avatar
The latch moves alright I lubed it up with silicone spray and worked it for about 10 mins
I did notice the bottom of the latch hook when I open the door I can push the latch down is that normal
Steve
Old Nov 30, 2016 | 07:08 PM
Yes...you can push the latch hook down even further after the door is opened. Here's a pic of mine after opening the door...without pushing the latch further down. The forward jaw or hook just clears the bottom of the door jamb striker. This is the factory setting on a lower mileage all original car who's body panels have never been touched and the doors have no sag.
Old Nov 30, 2016 | 07:38 PM
texxas's Avatar
Sammie, lets see a picture of your door striker that the latch fits on when the door is closed. There should be a plastic bushing around the striker as Joe mentioned, without it the door rattles and seems not latched properly when closed.
Old Dec 1, 2016 | 02:39 PM
sammieolds's Avatar
Door pin
Ill get some pics sat im not around till then
thanks Steve
Old Dec 2, 2016 | 08:33 PM
texxas's Avatar
Sammie, no bushing on the striker shaft. You can adjust it all day and it won't close correctly without the bushing.
https://classicoldsmobile.com/forums...ch-issues.html
Here's a thread with the part number to the part you need to fix the problem, one for each door. I understand the silencer bushings are getting hard to find. Good luck.
Old Dec 3, 2016 | 06:49 AM
sammieolds's Avatar
Here's the pass side close fine I think they wrapped that 1"fiber tape around the pin ?Do you think that will work I can't get that number anywhere It's discontinued
Steve
Old Dec 3, 2016 | 07:15 AM
sammieolds's Avatar
I don't believe it but I took some duck tape ripped to right size and wrapped around pin and it's shuts beautiful
Thanks for the idea
Not sure how long it will last but it's good for know
Steve
Old Dec 3, 2016 | 10:48 AM
texxas's Avatar
Originally Posted by Andrew Anatian
Hey, reply on my post and give me your thoughts please!
My thoughts are have some patience and don't troll for replies in other threads. Welcome to ClassicOldsmobile.
On finding the silencer bushing, if they are discontinued that really sucks because they just don't last long. I know Dorman/Help! section at local auto parts sells the complete striker with the bushing installed. I would imagine they will start selling the bushings. They even have a request area where you can suggest parts for them to manufacture, market and sell.
I would find some vinyl tubing or plastic pipe that fits tight on the striker neck and "make" a bushing out of that. Maybe a piece you can heat to slip on the striker neck that would be tight when cool?
Old Dec 3, 2016 | 01:51 PM
sammieolds's Avatar
Thanks for the info If I take that pin all the way our will the plate fall in the door
One guy told me it won't,but I think it will, I. Was going to try a strong magnetic to hold in place do you think that will work
Steve
Old Dec 3, 2016 | 04:45 PM
Plate will NOT fall down in the door. I've removed a number of them and know this to be true.
Old Dec 3, 2016 | 05:07 PM
texxas's Avatar
Yeah because it's in the rear quarter, it would be amazing if it fell into the door, I guess if you removed the flow through ventilation vent and stood the car on the front bumper and shook it? It won't go any where if you unscrew the door striker.
Old Dec 3, 2016 | 07:14 PM
oldolds88's Avatar
sometimes, sometimes it will fall into the 1/4 because the guy on the line had to do a repair to the striker nut and couldn't put the cage back around it, or the cage wasn't there from the beginning. I worked there. 99.9 % of the time youll be ok. but theres that 1 time
Old Dec 4, 2016 | 01:48 AM
allykatt 1992's Avatar
DSA736 in fusick catalog . 20 each .
Old Dec 4, 2016 | 03:45 AM
sammieolds's Avatar
Good one texxas Thanks for the all the info
Guys
Steve
Old Dec 4, 2016 | 12:21 PM
texxas's Avatar
I checked that part number and it is for the whole door striker at $19.50.
I didn't see just the bushing available.
Old Dec 4, 2016 | 01:19 PM
Just bushing im not sure about ?
Old Dec 4, 2016 | 02:12 PM
Here you go. You get (4) of them for $7.99 shipped.
http://www.ebay.com/itm/Door-Lock-St...3D400696055552
Old Dec 5, 2016 | 03:29 PM
sammieolds's Avatar
Thank Guys for all the info
steve
synergy10
Aug 6, 2016 03:44 PM
dedsleds
May 23, 2012 08:49 AM
dedsleds
Mar 23, 2012 01:54 PM
kevinw
Feb 21, 2011 08:29 AM
dedsleds
Feb 13, 2011 06:43 PM
