1973 ninety eight right 1/4 extension nos.
Old Jan 15, 2011 | 07:03 PM
dbbigyellowcar's Avatar
wanted 1973 ninety eight right 1/4 panel extension nos or good used NO reproductions as they are not of good quality Thanks.
Old Jan 16, 2011 | 12:28 PM
76 Regency's Avatar
Hi, while I don't have the filler you need, I share this same need for my '76 Ninety Eight's. Check out this post I started a few days ago where I am starting to work with a manufacturer to reproduce these parts in ABS plastic. I'm hoping to generate a good amount of response on there to help show the need for these parts to be reproduced correctly, not like what is curently out there. Good luck and let's keep our fingers crossed that we get lucky with this pursuit!
https://classicoldsmobile.com/forums...ety-eight.html
Old Jan 16, 2011 | 02:04 PM
rocketraider's Avatar
Oldsdruid
For some reason I was thinking 73 used a cast potmetal taillight housing extension?
Old Jan 17, 2011 | 04:10 AM
OldsMotion's Avatar
OldsMotion
Unless he is speaking of the bumper filler panel? I have a 73 or 74 tail light and extention and you are right, its metal.
John
Old Jan 17, 2011 | 04:46 AM
Thanks for replying but the filler I need is made of some sort of rubber or plastic they are usually always cracked off of 73's they are one year only and are nearly impossible to locate. the reproduction fiberglass ones that I tried are of poor quality. Don
Old Jan 17, 2011 | 08:49 AM
76 Regency's Avatar
Right, all of the fillers (quarter extensions) on the '71-'76 Ninety Eights are urethayne (rubbery plastic) and eventually dry out and crack. The taillight bezels are made of pot metal. The '73 has to be even harder because it is a one-year only model, that is about the only advantage I have with my '76 is that the fillers are identical on a '75. I wish I could say that meant there were plenty of available options but it doesn't at all. We really need a GOOD solution for these parts.
rmustang
Nov 4, 2012 05:00 PM
dbbigyellowcar
Oct 6, 2009 05:48 PM
John Rock
Ninety-Eight
Mar 31, 2007 03:21 PM
John Rock
Ninety-Eight
Aug 23, 2006 07:41 PM
