1972 Supreme/350 Heat Riser Tube
Old Apr 28, 2020 | 11:05 AM
72Supreme4Speed's Avatar
Trying to locate an original exhaust heat riser tube for 1972 Supreme with 350. Should have holes on bottom which are inline/across from each other to fasten together with mating bracket on passenger side exhaust manifold bracket using a pin, other end of tube connects with air cleaner snorkel. I am also in need of the connecting pin, a decent picture of a connecting pin, or any input on what pin is being used for restorations would be appreciated.
Dan
Old Apr 28, 2020 | 12:21 PM
70Post's Avatar
Dan - The "connecting pin" is just a long cotter pin. I'll try to find an example here and post a pic and/or a measurement. Basically, the cotter pin needs to be long enough to pass through everything and leave enough room on the other end to bend the cotter pin ends SLIGHTLY (the factory didn't bend the pin ends all the way flat, etc).
Old Apr 28, 2020 | 01:00 PM
vette442's Avatar
Factory original tube/bend/pin (Low mile unrestored '72 455). Your heat stove/shield will look different on a 350:
Terry
Old Apr 28, 2020 | 01:25 PM
oldsmoboogie's Avatar
I have a good heat riser tube from my 72 350 if your interested.
Old Apr 29, 2020 | 04:59 AM
jollyolds's Avatar
did u get my pm??
Old Apr 29, 2020 | 07:53 AM
Yes, how about 20 dollars plus shipping.
brandon reynolds
Apr 12, 2026 06:18 AM
stlbluesbrother
Jul 9, 2024 12:04 PM
oldsmobilejim
Mar 25, 2020 06:12 AM
yellowrocket
Apr 27, 2016 04:42 PM
JpMotorsports
Dec 19, 2014 07:15 AM
