1970 Oldsmobile Quadrajet
Old Jan 25, 2020 | 03:37 PM
w30brad's Avatar
I'm looking for a 1970 Quadrajet 7040250, 7040251, 7040252, 7040253 or 7040257 in need of a rebuild.
Must have main body casting number 7042305. A parts only carburetor is okay as long as the main body is intact.
It doesn't matter which part number or date code is stamped on the side, as long as the body (bowl) has part number 7042305 on the back.
Part number on back of body:
Old Jan 25, 2020 | 07:16 PM
rocketscientis's Avatar
Time has come to unass some carbs
17085214
2.375 % - 3. 1875 % but no more than 4.42 % of th wallo cores would be a reasonable number ...posssibly 6 or 7 carbs total depending upon request / time restraints as priority one is something entirely diffrent but do my best
, actually better 'n that to accomadate all fone calls to my fone from others fones & txts to aformentioned...my fone
It would be splended if all actually intested in obtainin a fuel air mixture creator txted me an email address suitable for image transfers of your core to be for inspection
With you my good fellow bein numero uno on items not pendin sale currently
Old Jan 26, 2020 | 06:00 AM
ROCKETMAN269V's Avatar
I have numerous Q-jet cores. I'll see if I have a parts carb that will donate the main body for your needs. Thanks, Bob.
Old Jan 26, 2020 | 06:12 AM
w30brad's Avatar
Sounds good, thank you!
Old Jan 26, 2020 | 07:25 AM
tru-blue 442's Avatar
Old School Olds
Brad, if you don't find what you needed, I have one from a 71 Toro with the correct body.
Old Jan 26, 2020 | 11:39 AM
jollyolds's Avatar
pm sent
Old Jan 27, 2020 | 02:47 AM
Located two 7040252s
Will double check for required casting # & send pix to any email adress that you provide
thanks
Old Feb 8, 2020 | 01:20 AM
Confirmed
7040252 available
Old Feb 8, 2020 | 07:18 AM
newmexguy's Avatar
"Carmantx" a carb guy in Texas on the Buick site, and probably others - recently (last year or so) purchased 1400 or so carbs from a full time seller in Michigan. Just a heads up.
Old Feb 9, 2020 | 03:36 AM
w30brad's Avatar
Thanks newmexguy
alain
Feb 1, 2017 01:52 PM
DocOldsW30
Feb 5, 2013 09:54 AM
1970VistaCruiser
Sep 22, 2012 05:34 PM
fast67vellen2o
Jun 22, 2011 11:33 AM
agtw31
Mar 15, 2007 01:49 PM
