1970 Delta custom clock delete cover
do a search on eBay, actually a couple:
*69 Olds* clock
*70 Olds* clock
that will get you both clocks and delete plates and yes 69 & 70 are the same, as is 88 & Ninety Eight
then save the search, you will get an email every morning with new listings
I found TONS of stuff this way
*69 Olds* clock
*70 Olds* clock
Since you have to go thru the same thing to R&R the delete plate as to install a clock, why not upgrade to clock when you do it? Clock was commonly dealer installed.
BTW, your car was NOT ordered "clock delete". That's the way Deltas came unless the clock was ordered. It was standard on Ninety Eight, extra-cost option on Delta.
