1970 442 horns
Old Oct 17, 2009 | 10:51 PM
shot12's Avatar
1970 442 horns
Looking for a set of horns(high and low note) for 1970 442.
Old Oct 18, 2009 | 11:46 AM
svnt442's Avatar
Finding originals that are not shot is almost impossible. You can buy replacements but most are in 2 pieces instead of riveted together like the originals.
Old Oct 18, 2009 | 02:08 PM
4-ever-olds's Avatar
Sorry if this is a stupid question, but are 442 horns different from other Cutlass horns? Different sound or design?
Old Oct 18, 2009 | 02:32 PM
svnt442's Avatar
Same.
Old Oct 18, 2009 | 04:34 PM
Shot12: I might have a set for you...I'll take a look & let you know
Old Oct 18, 2009 | 06:58 PM
shot12's Avatar
Thanks 4-ever-olds, I appreciate it.
Old Oct 18, 2009 | 07:06 PM
Cameo White's Avatar
Smile
I have an NOS set if you are looking to go that way. PM me for me info if you want.
Old Oct 18, 2009 | 07:20 PM
Here's the two sets of horns that I have.....The all steel set came with a 72 Supreme and the rusty steel and plastic set were in my 70 Supreme...I can't say for sure if either of them are original. I bench-tested both sets and they seem to work fine....at least that's what the neighbors all said!!
Let me know if either of these will work for you....unless you go with the NOS
Old Oct 18, 2009 | 08:31 PM
2blu442's Avatar
4-ever-olds I think my 1970 has the original horns. If I get home before dark Monday I'll see what numbers they have stamped in them.
Randy, if you think yours are original that might be a good check to see if we come up with the same numbers.
Eric, if shot12 doesn't go with your NOS ones could you post the numbers on those too so we can help him get the correct ones? John
Old Oct 18, 2009 | 09:13 PM
Horns identification
2blu442: I took a quick look on ebay and it looks like the all-steel ones are the correct horns. The ones I have both have "9000" in raised numbers in the casting and are stamped with "283" on one and "284" on the other. They both have "2C5" stamped on them as well (date code maybe?) The 283 has the letter "M" above the Delco-Remy and the 284 has the letter H in a circle above the Delco-Remy which I'm guessing would represent the tone of the horn?
Old Oct 18, 2009 | 09:47 PM
svnt442's Avatar
I have my originals on the shelf in the garage. They are SHOT and useless (sound like rattles when I shake them) so I replaced them with some parts store horns so I would have something. I'll get a pic of them to compare.
EDIT: They need to be cleaned up pretty badly. I can't see any numbers on them. I'll see what I can do. I did take pics of them and can post for physical comparison, but that would be the extent of it for now until I can get them cleaned up.
Old Oct 19, 2009 | 07:58 PM
2blu442's Avatar
Sorry, I had to work late and by the time I got home I totally spaced it out!
Old Oct 19, 2009 | 11:27 PM
shot12's Avatar
Not a problem 2blu442, thanks for your help.I think the all steel ones that 4-ever-olds has are the correct ones for my car.
Old Oct 20, 2009 | 06:41 PM
shot12's Avatar
horns purchased
Picked up the horns 4-ever-olds offered me. Thanks to everyone for there help.
costpenn
May 25, 2014 02:20 PM
Pacecar
Oct 16, 2012 05:13 PM
rroth01
Oct 25, 2010 01:30 PM
troberts6
Jul 18, 2007 05:34 PM
