1968 real 442 passenger fender not cutlass wanted
Old December 8th, 2021, 09:25 PM
TiborVerebi's Avatar
Hi I'am restoring my 1968 442 4 speed car and need a passenger front fender
with the correct hinge holes and emblem holes
does anyone have one available
please let me know
Thank you
TiborVerebi is offline
Old December 9th, 2021, 01:46 PM
442mark's Avatar
With or without W36 stripe?
442mark is offline
Old December 9th, 2021, 02:03 PM
Thank you with out the stripe
I will repost in wanted
Old December 9th, 2021, 02:41 PM
Randy C.
rcorrigan5's Avatar
There are two different hole patterns for the 4-4-2 numbers on the fenders in '68 - one with the W36 stripe and one without the W36 stripe. As well, you'll be lucky to find one that was specifically drilled for the 4-4-2. Your chances will be better if you look for an F85/Cutlass/4-4-2 fender and amend the holes to fit your pattern. It opens the field quite a bit. The 2-bolt hinge holes are the same for all 3 models.
Randy C.
'68 4-4-2 convertible
'69 4-4-2 convertible
rcorrigan5 is offline
Old December 9th, 2021, 02:47 PM
Thank you for the info also without the w36 stripe
I'll keep looking so far no luck on any 68 passenger fender
someone told me it was an early 68 because it does only have the 2 hinge holes for the hood
not the 5 like replacement or later
Thanks again
Iam going to see if I can get one at least with the 2 hinge holes fender and maybe drill for emblems and go from there
Old December 9th, 2021, 07:29 PM
442mark's Avatar
I'm in Washington state and have a passenger 68 Cutlass S fender available. It's solid and has the 68 2-bolt hinge mount pattern only.
442mark is offline
Old December 10th, 2021, 07:31 AM
Hi
Thanks for the reply Iam in Washington state also
could I get some pictures of hinge area eyebrow molding area and of course rear brace lower heel area inside and out
and what price did you have in mind and go from there
please give me a call and send pictures to my phone 509-679-2604
I'am definitely interested I could probably pick up
just let me know
Thanks again
Old December 10th, 2021, 05:51 PM
442mark's Avatar
Okay Tibor, I'll get you some pictures of all the areas you mention.
442mark is offline
Old December 10th, 2021, 06:19 PM
could you give me a call or I could give you a call
that would be great
Old December 11th, 2021, 02:09 PM
Ultra Tweaker's Avatar
Not to hyjack te thread but..........442Mark do you have a good driver fender? I"m in Coeur d alene working on a '68 442.
Ultra Tweaker is offline
Old December 11th, 2021, 04:50 PM
Hi mark .was wondering when we might be able to communicate about that passenger 68 fender
Tibor
Old December 11th, 2021, 05:08 PM
442mark's Avatar
Tibor
Hi Tibor, I'll call you in a few minutes.
442mark is offline
Old December 11th, 2021, 05:10 PM
442mark's Avatar
Yes I do, both Cutlass & W36 442 stripe driver sides.
442mark is offline
Old December 11th, 2021, 05:15 PM
Mark, sent you a pm. Thought I better quit jacking the thread.
BeenThere
July 21st, 2017 03:37 PM
ca68
March 21st, 2017 05:39 PM
68s350
October 23rd, 2015 11:29 AM
warrior71
June 14th, 2010 07:00 PM
1968Cutlassfallbrook
April 9th, 2010 05:07 PM
Quick Reply: 1968 real 442 passenger fender not cutlass wanted
